biesse rover 316 retrofit
4 years 9 months ago #231453 by Masiwood123
here is the sound of the engine that I can not eliminate in any way (can pwm be increased to 20k is limited), unfortunately linux mint 19.3 does not recognize the 7i92 card at start configuration, ie it throws out an error at startup, although I entered good network parameters, also debian on pc also freezes, I chose the second kernel when starting the computer but the same..after 1-10min jogging..this is so complicated :)
4 years 9 months ago #231457 by PCW
Replied by PCW on topic biesse rover 316 retrofit
Sounds like the PWM frequency.
LinuxCNC crashing is not common and probably indicates a hardware issue
with the PC.
The following user(s) said Thank You: Masiwood123
4 years 9 months ago #231475 by Masiwood123
if it should be pwm does it can be increased over 20k, in pnconfig it is disabled and fixed? we will see on other axis whan i connect all.
now i am trying to install and enter the pnconfig in mint 19.3, if it doesnt work will change pc as next step, even i think is ok Dell 980, i5 8gb ram nic on board.
4 years 9 months ago #231476 by PCW
The PWM rate is set by the drives, there is nothing on the LinuxCNC side that can change it
4 years 9 months ago #231493 by Masiwood123
which would be the recommendation of the computer?  maybe what freezes the whole linux has to do with the computer, and whether it is acceptable and better to insert ssd hard due to vibration (to note that my computer is in a closet where there is a lot of vibration.
4 years 9 months ago - 4 years 9 months ago #231620 by Masiwood123
Little progress today (big for me) I found that the freezing of linux is hopefully because of Pc, I replaced Pc today and after an hour nothing bad happened, following Tommy's instructions I got to the point when looking at halscope (but I'm not really clear that straight line..somehow everything goes fast and I can't see what's going on)..to be continued:)
Motor still sounds at high frequency both in operation and while standing. when I turn on all three axes the orchestra will play :)
Last edit: 4 years 9 months ago by Masiwood123.
Time to create page: 0.165 seconds
