biesse rover 316 retrofit
4 years 9 months ago #233567 by tommylight
PncConf will not help with 7i66, start LinuxCNC and use "show hal configuration" to find the pins.
And do check the red wire on the orange connector on the 7i77, it looks like it is falling out of place.
4 years 9 months ago #233568 by Masiwood123
ok i connect now on sserial on 7i77 as you suggested before direct.. now we will see..( red wire is ok i just bend wire and look like on photo as it’s not connected)..Hvala:)
4 years 9 months ago #233570 by Masiwood123
  Now see her in hal config!-:)) if I can't see it in pncconf ... how can I put these outputs to work via MDI 62-65 or M6 (unclear to me) so i would like that these outputs activate the drill solenoids?
4 years 9 months ago #233574 by tommylight
LinuxCNC = Ducati "Virus"
PncConf = bike with training wheels
Make a config that does basic stuff, save a copy, start editing the hal and ini files.
Now you have the pin names so adding them to the hal file and wiring them to solenoids and other stuff is a simple as:
net somesolenoid hm2_7i92.0.7i66.0.2.output-00
or
net machine-is-enabled hm2_7i92.0.7i66.0.2.output-04
4 years 9 months ago #233577 by Masiwood123
``LinuxCNC = Ducati "Virus"
PncConf = bike with training wheels``image missing /media/kunena/emoticons/smile.pngimage missing /media/kunena/emoticons/smile.pngimage missing /media/kunena/emoticons/smile.png
thank you Tom but i have to learn and learn...
ok it is clear to me to just write that lines to hall(maybe)..maybe stupid question ..but i want to activate for example solenoid(1) by mdi (example)M64 P01 and in gcode maybe..
How Linuxcnc know that i want P01(output) from 7i77 or P01(output) from 7i66 ,by MDI command?
4 years 9 months ago #233578 by Masiwood123
do i need to write M1xx user defined M codes ?
Time to create page: 0.289 seconds
