biesse rover 316 retrofit
4 years 9 months ago - 4 years 9 months ago #233648 by PCW
Replied by PCW on topic biesse rover 316 retrofit
The 7I66 pins will have different names in the hal file
How you map them to digital outputs is up to you
for example:
net blue_light hm2_7i92.0.7i77.0.0.output-00 motion.digital-out-23
net mist hm2_7i92.0.7i66.0.2.output-11 motion.digital-out-07
net laser_on hm2_7i92.0.7i66.0.2.output-00 motion.digital-out-08
Last edit: 4 years 9 months ago by PCW.
4 years 9 months ago #233654 by Masiwood123
yes it is clear but i can’t understand example like
net solenoid-jedan motion.digital-out-00 hm2_7i92.0.7i66.0.2.output-00
net solenoid-dva motion.digital-out-00 hm2_7i92.0.7i77.0.0.output-00
even there is different names,
in hal configuration in pins there is the the same output for 7i77 and 7i66 is named output-00
than what should happen if i put Mdi M64 P0? it will run output-00 from 7i66 or from 7i77 or? Thanks
4 years 9 months ago #233658 by PCW
Your example would not load because you are assigning 2 signals
( solenoid-jedan and solenoid-dva ) from one source pin ( motion.digital-out-00 )
which is illegal.
net solenoid-dva motion.digital-out-01 hm2_7i92.0.7i77.0.0.output-00
Would be legal
The following user(s) said Thank You: Masiwood123
4 years 9 months ago #233659 by Masiwood123
in that legal way M64 p0 will run 7i66 , and M64 p1 will run 7i77 output -00, right?
4 years 9 months ago #233660 by PCW
Yes
4 years 9 months ago #233661 by Masiwood123
oo finally i understand:) thank you very much!
Time to create page: 0.362 seconds
