biesse rover 316 retrofit
4 years 8 months ago #235134 by Todd Zuercher
As to your pause, make sure there aren't any discontinuities or sharp corners in your g-code if possible. The machine is going to have to slow down for any sharp corners, if it is going to meet the acceleration constraints of your configuration.
To minimize the affects of this use the highest acceleration rates the rigidity of your machine, and strength of your motors will allow.
That said...
(The following may contain potentially heretical statements and opinions read at your own risk.)
Warning: Spoiler!
4 years 8 months ago #235172 by Masiwood123
I would never remember :) this means a lot to me, I put less acceleration, I think 400, I think it can be doubled even so I'll try..if it doesn't work I'll try the spoiler. Thanks a lot
4 years 8 months ago #235176 by Masiwood123
gcode is from solidcam. *.nc extension ,arc has I an d J incremental mode.
4 years 8 months ago #235182 by Masiwood123
Here is my Ini file, there is no ARC_BLEND_ENABLE =`` in TRAJ section. should I add it?
File Name: new_2022-02-17.hal
File Size:12.1 KB
File Name: new_2022-02-17.ini
File Size:3.87 KB
4 years 8 months ago - 4 years 8 months ago #235209 by Todd Zuercher
The default setting is ARC_BLEND_ENABLE = 1, so if it is not present that is what it is. If you want to try the old planner add the line and set it to 0. It won't hurt anything and if you want to switch back to standard set it to 1.  Remember you do have to shut down and restart Linuxcnc for configuration changes to take effect.
Last edit: 4 years 8 months ago by Todd Zuercher.
The following user(s) said Thank You: Masiwood123
4 years 8 months ago #235230 by dgarrett
Replied by dgarrett on topic biesse rover 316 retrofit
"Remember you do have to shut down and restart Linuxcnc
for configuration changes to take effect."
hal pins can alter the settings:
> ini.traj_arc_blend_enable
> Allows adjustment of [TRAJ]ARC_BLEND_ENABLE
Ref:
$ man milltask
linuxcnc.org/docs/2.8/html/man/man1/milltask.1.html
See NOTES for restrictions
The following user(s) said Thank You: tommylight, Masiwood123
Time to create page: 0.375 seconds
