biesse rover 316 retrofit
4 years 8 months ago #235262 by Masiwood123
unfortunately changing arc_blend_enable = 0 or 1 has no effect, feedrate is drastically reduced at the entrance and exit of the curve. I increased the engine acceleration to 600 the same.
I insert arc_blend_enable = 0 just in ini file..ahve to check what is in hal?
www.youtube.com/shorts/nN50b9CzEUQ
www.youtube.com/shorts/GV75rVuPlfc
4 years 8 months ago #235272 by tommylight
Looks like something in gcode is causing that, so can you use Inkscape to generate a simple shape using built in extensions>gcodetools>path to gcode.
4 years 8 months ago #235277 by Masiwood123
i am using just solidcam for this i am working on wood chairs.. i can try simple circles gcode from aspire to export as ngc not nc as is in solidcam. i take a look in hal pins it’s now false in arc blend enable but the same situation with exact stop at arcs. Will check with gcode exported as ngc with same contour as in solidcam. but just to check.. in practice i must use solidcam for toolpaths.thank you
4 years 8 months ago #235280 by tommylight
Ok, try adding
G64 P0.5
at the top of the gcode file, if 0.5mm of tolerance is OK, try also lower values like 0.3 or 0.1, see if that helps.
The following user(s) said Thank You: Masiwood123
4 years 8 months ago #235282 by Masiwood123
yes, I added that too, although I think P0.1, I'm not at the machine now, but I'll see tomorrow, maybe a higher value will help :)
4 years 8 months ago #235283 by Todd Zuercher
I agree, it looks like it might possibly be something in the g-code. Could you post a bit of the problem g-code that exhibits the problem for closer inspection.
Unfortunately I'm not familiar with Solidworks, so I may not be much help adjusting its settings to better optimize it's output, but we may be able to make general suggestions.
Time to create page: 0.332 seconds
