only small progress today (snow-covered)
I connected all the basic cables, encoders enable output and + -10v analog output everything works. following tommy's instruction i figured out roughly how it goes, now considering only one axis (Y)
my problem is shooting the encoder scale .. the encoder is 1: 1 connected to the motor shaft ,leadscrew is 25mm/rotation due to join error I can't read the right scale, the machine is still noise and the sound from the motor is strange. but standing on the scales of the engine. Can anyone suggest what approximate values I should enter in servo tuning?
As i calculated from the picture encoder is 500ppr, than 500/25mm is
20/1mm why is that on fill space x 4? I'm still afraid that I didn't enter a good output scale because I left it at 10 max and min and according to the suggestion of PCW it should be according to Figure 1083 and -1083 ff1 = 1?
Drivers (amps)I would say that they are not touched by any of the factory settings and that they are in velocity mode
Thank you for your help
