- Thank you received: 13
1 or 2 dedicated 120VAC circuits for my CNC?
- Sray69
3 years 9 months ago #261053
by Sray69
Replied by Sray69 on topic 1 or 2 dedicated 120VAC circuits for my CNC?
If I have a 200C wire that is rated at lets say 20A, would that be adequate for a 20A circuit if my temps are going to be nowhere near the 200C? Is the amp rating of the wire the same up to the 200C? Or does the amp rating go up as the temp goes up and maxes out at 200C? That sounds like a completely stupid question now that I read it, but I just want to be sure I understand it.
- spumco
- Thank you received: 905
3 years 9 months ago #261057
by spumco
Replied by spumco on topic 1 or 2 dedicated 120VAC circuits for my CNC?
- Sray69
3 years 8 months ago #264146
by Sray69
So I have the CNC completely wired except end stops. I forgot to order them. Will just any old limit switch work? Any recommendations?
- Thank you received: 7491
3 years 8 months ago #264149
Replied by tommylight on topic 1 or 2 dedicated 120VAC circuits for my CNC?
Ones made by Balluff are good, but be seated before checking the price!
Mechanical fully enclosed ones should do for metal mills and plasma, inductive ones also good but might need a bit of protection from debris.
Anything from Omron should do, since you are aiming for good quality.
The following user(s) said Thank You: Sray69
- spumco
3 years 8 months ago #264152
by spumco
I'm partial to NC 3-wire inductive proximity switches. I believe the trick with these is to mount them in a way that the trigger/flag crosses the sensing volume rather than approaches. Put another way, if you think of the proxy like a flashlight, you want something (flag) to cut the beam from the side rather than moving the flashlight towards the device you're trying to sense.
I've read they're more repeatable this way. And you aren't going to smash the proxy if something goes wrong and tries to hit the hard stop. And the NC circuit means if a wire breaks or something, the controller will see it as triggering the limit (fail-safe).
On the other hand, I've also used $0.25 cheapo microswitches as limits on a couple of low-budget builds. They weren't repeatable to a 'thou, but that didn't matter much for a stepper plasma and I could run them at 24vdc for some noise immunity (at the cost of the contacts burning out sooner).
As with everything, it's a cost-performance decision. If you have a table-mounted ATC, tool length probe, or specific fixturing you may wish to have very repeatable limits. Otherwise, anything that gets you in the ballpark and doesn't fail frequently should be sufficient.
- Sray69
3 years 8 months ago #264155
by Sray69
Time to create page: 5.800 seconds
