- Thank you received: 94
simple linux cam
- Reinhard
4 years 6 months ago #240045
by Reinhard
Replied by Reinhard on topic simple linux cam
Yes, you're right. Didn't though of that.
So what do you mean with gitter chat? I'm a noob with chat things
I mean, FreeCAD uses a lot of Python, but at its core it uses open cascade as well. It wouldn’t surprise me if you found some devs who know a good amount about it in the overall community.
- Thorhian
4 years 6 months ago - 4 years 6 months ago #240063
by Thorhian
Replied by Thorhian on topic simple linux cam
Gitter is basically just a fancy chat client that some open source projects use. You can access it on your browser. You can use your GitHub account to login to it as well if you want.
gitter.im/FreeCAD/FreeCAD?utm_source=sha..._campaign=share-link
It is linked to their IRC chat too, which I believe is on the Libera server if I remember correctly.
Just know that I found this thread and project because someone from the LCNC community posted it in FreeCAD’s Path workbench gitter chat. I believe it was CaptHindsight.
Last edit: 4 years 6 months ago by Thorhian.
- Reinhard
4 years 6 months ago #240230
by Reinhard
for those who like to give it a try ...
I published the sources
The following user(s) said Thank You: silopolis
- HansU
- Thank you received: 217
- Reinhard
4 years 6 months ago #240233
by Reinhard
Oups - sorry! I thought, I already posted the repo location.
Just updated first post
The following user(s) said Thank You: HansU
- Reinhard
4 years 6 months ago #240371
by Reinhard
the next hurdle has been taken. I wanted to mill the open pockets.
The least effort for the user seemed to me to cut the model horizontally and derive the contour from that.
However, the parallel contours were not suitable as a tool path.
So - roll up my sleeves and spit into my hands ...
Although opencascade provides the tools to edit a curve, it was not possible for me to get the desired result. So I had to cut the curves myself. In doing so, I had to realize that opencascade creates completely chaotic curves. Different directions and completely different start and end point ...
(green is the first segment, red the last - contour with two green segment means first and last segment of the curve)
So I had to create my own data structure to get reliable results. This was a challenge for my gray cells, but I think I finally skinned the cat. (The steps in the rapid [cyan] are only for debugging)
Time to create page: 0.183 seconds
