Centroid CNC4
Would the existing steppers need greater capacity of say a Gecko 203V drive at 80v 7a? Or am I missing some huge chunk of the puzzle?
Good question and I'm not sure. The manual page for the Centroid MAE 1350 (M.A.E. HY200-4270-710 A8) simply lists the holding amps as 7.1 unipolar and 10 amps bipolar. The drives appear to be in a bipolar configuration. I'm not entirely sure what I really need. I believe the Gecko would drive the stepper and I really doubt it would need 10 amps in my application as I believe these steppers to be over sized. It's possible my manual has the power supply specs someplace. Does Gecko have anything larger than 7 amps?
Here is a link to the spec sheet, the stepper is listed on page 22:
www.sodimatel.fr/image_base/Img_1637.pdf
From the manual:
"Drive Type: Open loop or closed loop 50 VDC bi-polar micro-stepping
chopper-drives, 8 amps/phase max, 8 micro steps per full step. (1600
microsteps per revolution at a 1.8 degree stepping motor)"
So if the G203V will do 80V 7A... that's 560 watts vs the 400 watts delivered by the Centroid. The Gecko is 40% more powerful. I think the G203V drivers would work dandy.
Am I looking at this correctly?
Bonus is I'd pick up 400 more micro steps also
UPDATE: Wouldn't the G213V be better than the G203V because it support micro stepping?
Not really as steppers don't really work that way. However, going from 50V to 80V will give you a lot more speed. (or, more accurately, the same torque at higher speed)
I am not a huge fan of high microsteps. 4x is about as high as I see any point going.Wouldn't the G213V be better than the G203V because it support micro stepping?
I'm really trying to find out if the driver is sized appropriately for these steppers. Additional speed would be great
Wouldn't the G213V be better than the G203V because it supports micro stepping?
I'll have to dig through the manual and the settings and see if I the current control is using micro stepping. I suspect it is using the 8 micro steps as specified. I'd be inclined to duplicate that unless there is a really compelling reason not to. My understanding is that micro stepping is smoother than full steps at the expense of speed and torque.
Yes. You also lose some positional repeatability. (you get more positions, but they are less well defined).
The thing to do is to experiment, changing microsteps is easy.
There is a page on the wiki that has stepper formulas to help figuring voltage and such.
As far as how my motor is mounted, my setup is completely different than yours because I have a bridgeport that has a BOSS knee on it. So the motors are mounted in the same configuration as the original ones. I have however seen machines set up the way you would like to change yours to. Seems a little weird that the motor is mounted in the back like that.
Forhire, I have a computer to use for the terminal, it runs windows now but was considering switching to linux because it seems there is more peer support for linux. My CNC4 works just fine as far as I can tell but I have yet had time to really try it out, I just got the machine about 2 weeks ago. I have the manual and cencomm software but would like to use a more modern program to control it. I would really like a program that graphically shows changes to the gcode as I program.
I have never used the cencomm software. On Windows you can use HyperTerminal which is bundled with many versions of the OS. Generally it is found under Accessories, Communications. I know ProComm supports all the features to drip feed the control. Normally the g-code is generated by your CAM software or you write it by hand. The cnc4 control is a great control to learn basic g-code, especially if you have the manual.
You should look at NCPlot ( www.ncplot.com/ ), it is inexpensive, is a handy editor and has a graphical viewer. It also supports DNC so you can send files to the controller. I don't know if it works with the cnc4 as I haven't tried it. I frequently use this to verify code before sending it to the control.
The BOSS was designed for CNC from the beginning. I assume you have something like a Boss 3? Your using the factory steppers?
Yeah, I have whacked the encoder a time or two. I tore it apart today, drilled a few holes, flipped it around. I gained 6 inches of travel and I will never hit the stepper/encoder again. I should have done this years ago
