Centroid CNC4
So I have everything all hooked up now. Not really sure if I am doing everything correctly. Using option 4 do I have to type each line as I go? I cant figure out how to send a complete file to the controller.
Program can be loaded using the Edit menu, option 7. Programs larger than 24k characters can be fed line by line through the MDI which is option 4. Line by line feed requires the transfer to wait for a "?" before sending another line. Either method you transfer the program using ascii transfer. What terminal program are you using?
fedorahosted.org/released/gtkterm/
It's possible the Ubuntu repository has been updated and you already have the fixed version.
Make sure you set your X0, Y0, and Z0 positions using 6 and option 8.
To load a program into memory:
Press 7, Edit menu
Press L to list program in memory
Press K to kill or erase program in memory
Press I to insert or load program from file
Click on File in gtkterm, Send Raw File, select your gcode file, this will then load the program into memory
I normally then list (L) the program to make sure it's complete. Memory is limited to about 1000 lines or so. Press X to leave the Edit menu. Press the green start button to run the program. Program will run each time you press the button. Nice for multiples.
To feed the program line by line from a file:
Click Configuration in gtkterm, select Port
Check the "Wait for this special character before passing to next line" and enter ? (question mark) in the box.
Press 4 in CNC4 which opens MDI mode
Click on File in gtkterm, Send Raw File, select your gcode file.
Program will start running line by line intermediately.
Don't forget to remove the wait character when not using MDI.
What baud rate are you running? I use 9600, I haven't been able to get 19200 to work... even after changing the dip switches. Just curious.
you said you are missing a few pages from your manual? I have a complete one. I wouldn't mind sending you copies of the pages you are missing.
Thanks for the step by step. I will try it out when I get to work Monday. I have been trying to write a bit of gcode so I will try one that I have made. Im running 9600 baud rate just because thats what the manual says to run.
Sounds good. I've been trying to get the 19200 to work so I can maybe squeeze some more speed out of the control. I spoke with Centroid and they were certain it works... but I've never been able to do it.
forhire, you said you are missing a few pages from your manual? I have a complete one. I wouldn't mind sending you copies of the pages you are missing.
Super. I'm only missing page 65 or something. I'll look it up on Monday. I figured out the command without it... but it would be nice to have it. Not sure if I'm missing other pages
![:P :P](/media/kunena/emoticons/tongue.png)
Page 65 and 66 are missing. I may be missing others but that one I know for sure as it covers G80 - G83. A scan of those two pages would make the manual complete.
![B) B)](/media/kunena/emoticons/cool.png)
From Gecko page www.geckodrive.com/ark-2/support.html
To figure out what the maximum power supply voltage should be, use the following formula with the motor’s inductance in millihenries (mH) used for the L value.
32 * VL = VMAX
My steppers have a phase inductance of 1.8 mH but I can't find the voltage on my old spec sheet. Should I assume it's something like 2.2V? This gives me 126.72V.
The new spec sheet lists the max voltage as 140V with a phase inductance of 2.0mH, same model number but clearly a little different.
So I should be OK building for a 70V power supply?
Here are the spec sheets for the steppers:
home.lewiscounty.com/users/forhire/hy2004270.pdf
home.lewiscounty.com/users/forhire/hy2004270-old.pdf
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Stepper_Formulas
