First Time Help
- Thank you received: 1373
The machine I am trying to do this on had/has DOS PC with a 48 bit I/O card and step dir servo drives.
The I/O card is configured by dip switches and jumpers, and does not use any drivers (at least in this application). It does have some timer/counter compatibility but they are not being used. Here is a link to its manual.
www.artisan-scientific.com/info/advantech_pcl_720_manual.pdf
The card connects to the router with 4 20 pin ribbon cables 2 with 16 inputs and 2 with 16 outputs. It is currently configured to use IRQ5 and addresses 300-303 for the I/O. I know what the DOS program was configured for. But I don't know how to translate this to EMC2.
For example the X axis uses
300 bit 2 for step
300 bit 0 for dir
301 bit 2 for limit hi
301 bit 0 for limit low
303 bit 2 for enable (input from servo drive)
Do I have to write my own driver?
Or is there an easy way/place to input all this information?
Is the I/O card a pci card?
If the servo drives take step and direction inputs there is the option to ditch the I/O card and replace it with something that is supported by EMC all ready... or write your own driver for your card.
I suspect that you will need to, yes.
The good news is that it probably isn't very difficult.
I think you could write the driver in comp
linuxcnc.org/docs/html/hal_comp.html
Something a bit like this:
component advantech "driver for advantech card";
pin out bit out x-step;
function read;
function write;
FUNCTION(write){
long reg300, reg 301;
reg300 = x_dir >> 0 || x_step >> 2;
reg301 = limi_hi >> 0 || lim_lo >> 2;
outb(0x300, reg300);
outb(0x301, reg301);
What prompted the Idea of a change was a lightning strike that took out the old PC.
I have already installed 10.04 on the new PC.
Max Interval 1002113 Max Jitter13140 Base thread max interval 38164 max jitter 13383
I was hoping not to have to redo all the wiring that was already done and works. Its nice to have something that just plugs in.
I can follow most of your code but I'm stumped by this line:
Can you expand a bit on what this line does just for my education?
Well, looking at it again it probably needs to use << and possibly | instead of ||.
<< and >> are bit-shift operators, so if x_step is 1 then x_step << 2 == 4, or bit 2.
What the code is doinf is bit-shifting the pin values to the rcorrct positions, then bitwise-or-ing them together into one byte
Neat Stuff!
Would anyone be interested in writing something up for me. I am sure we could arrange some kind of payment for your work.
If I can't make this work then I will have to try setting up something off of a couple of paralell ports
Here is what I gathered from our old programs configuration file. (there is a lot of stuff that isn't used on our machine though)
Address bit I/O Description
300 0 Out X Direction
300 1 Out Y Step
300 2 Out X Step
300 3 Out Y Direction
300 4 Out Z Direction
300 5 Out W Step (not used?)
300 6 Out Z Step
300 7 Out W Direction (not used?)
301 0 Out routers on (not used)
301 1 Out
301 2 Out dust boot (not used)
301 3 Out
301 4 Out
301 5 Out
301 6 Out Z tool bar up/down (not used)
301 7 Out
302 0 Out Z forward (not used)
302 1 Out Z spindle on (not used)
302 2 Out Z speed 13A (not used)
302 3 Out
302 4 Out Z speed 13B (not used)
302 5 Out W speed 13B (not used)
302 6 Out Z speed 13C (not used)
302 7 Out W speed 13A (not used)
303 0 Out Vacuum
303 1 Out W forward (not used)
303 2 Out spare 5VDC CPU SIGNAL
303 3 Out W spindle on (not used)
303 4 Out dust collector (not used
303 5 Out spare 5VDC CPU SIGNAL OR NEC OPTO
303 6 Out spare 5VDC CPU SIGNAL
303 7 Out spare 5VDC CPU SIGNAL OR NEC OPTO
300 0 In Z servo enable
300 1 In tool 6 (not used)
300 2 In servo enable (not used)
300 3 In tool 5 (not used)
300 4 In W low limit (not used?)
300 5 In tool bar up (not used)
300 6 In W hi limit (not used?)
300 7 In tool bar down (not used)
301 0 In X low limit switch
301 1 In Z hi limit switch
301 2 In X hi limit switch
301 3 In Z low limit switch
301 4 In Y low limit switch
301 5 In ?
301 6 In Y hi limit switch
301 7 In Master Enable Off
302 0 In tool in changer (not used)
302 1 In
302 2 In clamp (not used)
302 3 In Z spindle up to speed (not used)
302 4 In fan over temp (not used)
302 5 In tool 4 (not used)
302 6 In Laser (not used)
302 7 In tool 3 (not used)
303 0 In Y servo enable
303 1 In tool 2 (not used)
303 2 In X servo enable
303 3 In tool 1 (not used)
303 4 In W servo enable (not used)
303 5 In tool 8 (not used)
303 6 In servo enable (not used)
303 7 In tool 7 (not used)
It should be fairly easy to make a driver, I will try to do one later tonight.
In the meantime it is probably worth you going through the steps to make sure that "comp" works. I think you need to follow steps 1.3 here
wiki.linuxcnc.org/emcinfo.pl?Contributed..._install_a_component
It is probably worth checking that one of the simple example files in the comp page compiles and installs properly too.
I am very intrested in creating a driver myself for a custom board, but have tons of questions. I will wait to ask them until after we see the driver you create here.
After which, if its OK with you, I would like to start a thread in a more appropiate section and dissect your driver for the OP. So is this OK, and what section do you suggest?
