First Time Help
- Topic Author
- Thank you received: 1441
- Topic Author
- Topic Author
The way we normally advise people to use EMC2 is to use dumb drives and bring the PID loop inside the software. You have a fairly advanced PID controller with feed-forward and programmable limits. However, the big difference is that you can use Halscope to see exactly what is going on in the software, which makes tuning easier.
Step-direction servo drives are a bodge to allow simple digital outputs like parallel ports run servos.
I think EMC2 can run that machine a lot better. However I don't think it can do it in a short timescale. If you are interested then I suggest setting up a test system and experimenting.
What motors and drives are you using?
One very simple improvement, if the drives allow it, would be to switch to quadrature input rather than step/dir. It might even help with the tuning. (through indirect effects)
EMC2 has a huge range of supported hardware. Personally I rather like the Mesa 8i20 which is a 2kW brushless servo drive that takes angle/current commands in digital form direct from EMC2.
- Topic Author
Google is drawing a blank on that, do you have a spec?The drives are Teknic SST-1500-ALWs
There is a likely mismatch there, I suspect that the rack backlash is greater than the position resolution. Where is the feedback? If it is an encoder on the motor then that's OK. But if it is a linear encoder on the axis then the disparity will be important.It is currently set to 1000 steps/rev, on a helical rack and pinion drive (pinion is about 2" dia) with belt reduction. that ends up with about 1800 steps/inch
However, that carving looks to have problems mainly on the Z.
- Topic Author
The drive is a discontinued model but its specs shouldn't be that different from the superseding models.
Here is a link to the motor specs
www.teknic.com/files/product_info/3462_V1.3.pdf
after a bit of grubbing the net here is what I could find for the drive
www.cnczone.com/forums/attachment.php?at...=114568&d=1284412755
www.teknic.com/files/downloads/Teknic_SS...em_Manual_Rev3.8.pdf
Indicates that the drives can be used as analogue servo drives using +/-10V signals to command velocity or torque.
However, it is not guaranteed that that would make things much better, and it would mean buying different hardware and probably quite a lot of machine downtime.
- Topic Author
I think my best option is to spend some time properly tuning the drives. (time to boot back to win98 ick)
I am thinking of submitting the driver to the main project, and if I do that I think I would like to include a "reset" function like the parallel port has, which allows twice the step rate (it was originally called "doublestep").
The manufacturer didn't want to lend me a card to develop on (which I find disappointing)
If I do add this function, would you be willing to test it?
