First Time Help
- Topic Author
- Thank you received: 1369
30 Jun 2011 15:23 #11007
Replied by Todd Zuercher on topic Re:First Time Help
Yes I have and I am not seeing any changes in hal when depressing switches.
But I can see volt change when probing the connectors with a meter on the machine, while depressing the same switches.
It would appear the driver isn't really connecting with the card.
30 Jun 2011 16:00 #11009
Replied by andypugh on topic Re:First Time Help
Todd Zuercher wrote:
I checked that the 8-bit registers were actually being set correctly. Have you checked the outputs with a multimeter?
I couldn't check the "read" half of the driver without having the hardware. It contains a stupid copy-paste error.
Should readHowever, I don't think it is the cause of the problem, as the 0x301 address is the only correct one.
You could try adding the following lines near the beginning in the pin declarations, to see if the raw byte reads are working:
then in the "read" function after the inb() commands
(note that there is a deliberate substitution of "-" for "_" between the pin names and the associated C variables)
Well, yes. The question is "why"?t would appear the driver isn't really connecting with the card.
FUNCTION(read){
unsigned char R0, R1, R2, R3;
int i;
R0 = inb(base_addr);
R1 = inb(base_addr + 1);
R2 = inb(base_addr + 2);
R3 = inb(base_addr + 3);
for (i = 0;i <= 7;i++){
pin_in(i) = R1 && (1 << i);
pin_in(i+8) = R2 && (1 << i);
pin_in(i+16) = R2 && (1 << i);
pin_in(i+24) = R2 && (1 << i);
FUNCTION(read){
int i;
pin_in(i) = R0 && (1 << i);
pin_in(i+8) = R1 && (1 << i);
pin_in(i+24) = R3 && (1 << i);
pin out unsigned R0-pin;
pin out unsigned R1-pin;
pin out unsigned R2-pin;
pin out unsigned R3-pin;
R0_pin = R0;
R1_pin = R1;
R2_pin = R2;
R3_pin = R3;
- Topic Author
30 Jun 2011 16:21 #11010
This error, I need to fix the comp file and rerun it?
The other suggestions. Are these things that I should put in the Hal file?
I am feeling a lot of pressure from higher up right now. The machine has been down for a month. They are pushing me to give up and buy the manufacturers upgrade for the control for $3100. (seems kind of steep for just a PC with a $1400 software package).
It just seems so tantilizinly simple to write to x address, read another. but no, nothing is ever that simple.
- Topic Author
30 Jun 2011 17:44 #11015
when I try to do halrun I get this:
halrun
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 File exists
halcmd:
halcmd: exit
ERROR: Module pcl720 does not exist in /proc/modules
<commandline>:0: exit value: 1
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
ERROR: Module hal_lib is in use by pcl720_729c93108560bb40a3698e5d113e2951
ERROR: Module rtapi is in use by pcl720_729c93108560bb40a3698e5d113e2951,hal_lib
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem is in use by rtapi
ERROR: Module rtai_fifos is in use by rtapi
ERROR: Module rtai_sched is in use by rtapi,rtai_sem,rtai_fifos
ERROR: Module rtai_hal is in use by rtapi,rtai_sem,rtai_fifos,rtai_sched
digital6@digital6-desktop:~$
halrun
halcmd:
halcmd: exit
30 Jun 2011 17:46 #11016
by BigJohnT
Replied by BigJohnT on topic Re:First Time Help
Do halrun -U to unload an aborted hal and notice it is a capitol U.
30 Jun 2011 18:04 #11018
I have found that halrun -U almost never works…
- Topic Author
30 Jun 2011 18:21 #11019
Ok I restarted the PC, ran comp, then in halrun I now get this.
digital6@digital6-desktop:~$ halrun
halcmd: loadrt pcl720 ioaddr=0x2A0
halcmd: addf pcl720.0.write base-thread
HAL: ERROR: thread 'base-thread' not found
<stdin>:2: addf failed
halcmd:
halcmd:
30 Jun 2011 18:29 #11020
loadrt threads
show thread
addf pcl720.0.write thread1
addf pcl720.read thread1
start
show funct
show pin
etc….
show thread
start
show funct
show pin
etc….
30 Jun 2011 19:15 #11025
It looks like you need to find Pidgin in the Software Centre at the bottom of Applications.
There is an online client on this website here:
www.linuxcnc.org/component/option,com_mo...emid,8/lang,english/
but be warned that you get logged out if you navigate away from the page, so open another window/tab
However, somebody else on IRC spotted a serious error in that last bit of code.
the outb() command is (value, address) and I had (address, value).
The attached file might work better.
- Topic Author
30 Jun 2011 19:33 #11026
wo hoo! I am getting a change on the show pin readout now when I depress a limit switch.
Time to create page: 0.300 seconds
