EMC2 Crash on startup
04 Aug 2011 22:35 #12194 by mspyle
EMC2 Crash on startup was created by mspyle
When I try to launch EMC2 I get an error and the program closes, if anyone knows how to fix it short of reinstalling it would be great.
Error:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/matthew/emc2/configs/Sherline4Axis'
Machine configuration file is 'Sherline4Axis_inch.ini'
INIFILE=/home/matthew/emc2/configs/Sherline4Axis/Sherline4Axis_inch.ini
PARAMETER_FILE=stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
RTAPI: ERROR: Unexpected realtime delay on task 1
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
Unexpected realtime delay: check dmesg for details.
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=3087
Killing task milltask, PID=3155
Cleanup done
Debug file information:
File "/usr/bin/axis", line 3953, in <module>
get_coordinate_font(vars.dro_large_font.get())
File "/usr/bin/axis", line 3865, in get_coordinate_font
font_cache[coordinate_font] = fontbase = int(o.tk.call(o._w,
"loadbitmapfont", coordinate_font))
_tkinter.TclError: Could not allocate font
3087
PID TTY STAT TIME COMMAND
3155
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 9954.443417] I-pipe: Domain RTAI registered.
[ 9954.443431] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 9954.443436] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu
4.4.3-4ubuntu5) .
[ 9954.443499] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE
(INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 9954.443503] PIPELINE layers:
[ 9954.443509] f9539e20 9ac15d93 RTAI 200
[ 9954.443513] c085cb20 0 Linux 100
[ 9954.470543] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 9954.470759] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with
RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 9954.470767] RTAI[sched]: hard timer type/freq = APIC/12499948(Hz);
default timing: periodic; linear timed lists.
[ 9954.470773] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq
= 2999963000 hz.
[ 9954.470776] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 9954.471593] RTAI[usi]: enabled.
[ 9954.551887] RTAI[math]: loaded.
[ 9954.653236] config string '0x0378'
[ 9955.482564] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 9955.482576] This Message will only display once per session.
[ 9955.482579] Run the Latency Test and resolve before continuing.
[ 9955.483574] 811: ERROR: Unexpected realtime delay: check dmesg for details.
[ 9955.483582]
[ 9955.483583] In recent history there were
[ 9955.483585] 2996212, 2993235, 3009263, 2989170, and 2989635
[ 9955.483587] elapsed clocks between calls to the motion controller.
[ 9955.483593] This time, there were 4197532 which is so anomalously
[ 9955.483596] large that it probably signifies a problem with your
[ 9955.483598] realtime configuration. For the rest of this run of
[ 9955.483600] EMC, this message will be suppressed.
[ 9955.483602]
[ 9956.118220] RTAI[math]: unloaded.
[ 9956.158607] SCHED releases registered named ALIEN RTGLBH
[ 9956.189379] RTAI[malloc]: unloaded.
[ 9956.288151] RTAI[sched]: unloaded (forced hard/soft/hard
transitions: traps 0, syscalls 0).
[ 9956.292979] I-pipe: Domain RTAI unregistered.
[ 9956.293066] RTAI[hal]: unmounted.
I just got done installing the CNC upgrade package on my Sherline 5400 mill, and i am a new Linux user stumbling my way through figuring out how to use it.
-Matt
05 Aug 2011 09:52 #12208 by Rick G
Replied by Rick G on topic Re:EMC2 Crash on startup
Have you run the latency test?
If not you need to check that first and maybe edit the configuration to lower setttings.
Take a look here...
wiki.linuxcnc.org/emcinfo.pl?TroubleShooting
From your report...
Rick G
05 Aug 2011 16:43 #12223 by mspyle
Replied by mspyle on topic Re:EMC2 Crash on startup
I ran the latency test and I am still getting the same error
-Matt
05 Aug 2011 20:05 - 05 Aug 2011 20:09 #12230 by BigJohnT
Replied by BigJohnT on topic Re:EMC2 Crash on startup
What was the result of the latency test?
I assume you didn't adjust your config to suit your latency...
Last edit: 05 Aug 2011 20:09 by BigJohnT.
05 Aug 2011 20:15 - 05 Aug 2011 20:16 #12231 by mspyle
I got EMC2 to load no problem last week before I got the CNC box and stepper motors in hooked it all up and it decided it did not want to behave after i hooked em up. Where do I go to change the config? I do not have the latency test results on this PC but they are saved on the Ubuntu machine as soon as I get on it tomorrow I will post em. Everything I am using is new to me here sorry about all the questions.
-Matt
Last edit: 05 Aug 2011 20:16 by mspyle.
05 Aug 2011 20:55 #12233 by BigJohnT
I assume you used one of the sample configs... if so run the stepper configuration wizard and from it run the latency test and let it run a while. Then use the results from it and plug the number in and see what base period it creates for you. Copy that to your config, I'm guessing in your ini there might be an entry for that.
If you used one of the sample configs which one did you use?
06 Aug 2011 00:59 #12235 by mspyle
I used Sherline 4 axis inch sample, and that is the one that's crashing when I try to open it now to test everything.
-Matt
06 Aug 2011 13:05 - 06 Aug 2011 13:15 #12238 by BigJohnT
Just to be clear you can run the config but get the error RTAPI: ERROR... in the lower right corner?
Open up the Sherline4Axis_inch.ini file and change
BASE_PERIOD = 50000
to
BASE_PERIOD = 100000
I have a fairly good latency and I got the RTAPI: ERROR when I ran the config until I changed the base period to 100000
Last edit: 06 Aug 2011 13:15 by BigJohnT.
06 Aug 2011 16:29 #12242 by mspyle
When I try to open the Sherline sample file the whole program quits, I can open the stepper config no problem. I tried to open the .ini with gedit but it wont let me change anything on the file just view it.
-Matt
06 Aug 2011 17:19 #12244 by BigJohnT
How are you opening the sherline sample file and what program quits?
Lets back up a bit... did you create a local copy of the sherline config in /home/.../emc2/configs by starting EMC from the CNC menu and clicking on sample configs and picking the sherline config and saving the config to your local directory and this creates an icon to your desktop to start your config from?
If your mucking about in the files above your home directory you are in the wrong place.
Time to create page: 0.149 seconds
