EMC2 Crash on startup
14 Aug 2011 12:50 #12484
by BigJohnT
Replied by BigJohnT on topic Re:EMC2 Crash on startup
The Atom 525 might be better if you plan on using the parallel port as it is brought out to the rear panel and the 510 only has the header for the parallel port on the motherboard so you would have to find a cable to bring it out.
14 Aug 2011 19:20 #12488
by mspyle
Replied by mspyle on topic Re:EMC2 Crash on startup
I am using the Sherline 4 axis driver box so unless I can use a USB to parallel cable or a parallel card I am probably going to go with the Atom 525, If i can use a USB to parallel cable or a card I would rather get something that fits in the gateway case after I knock the back panel out. On the Atom are you using the on board graphics or a card?
-Matt
-Matt
14 Aug 2011 19:49 #12489
by BigJohnT
USB to parallel will not work with real time motion control.
PCI parallel cards are cheap and work.
The 510 and 525 have on board graphics only.
14 Aug 2011 23:40 #12492
by mspyle
I'm looking at:
Motherboard
www.newegg.com/Product/Product.aspx?Item=N82E16813121442
Ram
www.newegg.com/Product/Product.aspx?Item=N82E16820148191
Know anything about this case?
www.newegg.com/Product/Product.aspx?Item=N82E16811108227
I am going to try different video card drivers next, I tried them in 10.04 and that did not make any difference on the latency. I really want to use the hardware I already have but if its not possible I am buying parts.
-Matt
Motherboard
Ram
-Matt
15 Aug 2011 13:28 #12499
by BigJohnT
That's the same motherboard I have but I think I used this system specific memory in the 525.
www.newegg.com/Product/Product.aspx?Item=N82E16820139220
I used a different case to but that one looks good too.
15 Aug 2011 17:05 - 15 Aug 2011 17:06 #12500
by mspyle
I have had a couple of bad run-ins with Kingston thumb drives and ram (RMAd a thumb drive 5 times and then tossed it, Returned ram after it did not work twice and gave up) I prefer Crucial or Corsair but if it causes any problems I guess I will give it another shot.
-Matt
-Matt
Last edit: 15 Aug 2011 17:06 by mspyle.
15 Aug 2011 18:17 #12501
by BigJohnT
If you do a little googling you can find the ones that are system specific for the D525 motherboard... I think there was a couple brands that had been certified to work.
15 Aug 2011 18:24 #12502
by BigJohnT
Also if you don't need the tiny size of the 510/525 I have two Zotac's running EMC one in my Lathe and one down in the beer cave...
15 Aug 2011 22:47 #12506
by mspyle
The smaller the he better the gateway case doesn't really fit where I have it so I am going to stick with the 525 and I will look around for different ram. On your 525 are you using 10.04 or 8.04 and what drivers for the video card? Sorry about all the questions I just want to make sure I have got everything I need ready for when I buy this.
-Matt
-Matt
15 Aug 2011 23:11 #12508
by BigJohnT
10.04 and nothing special just popped in the LiveCD and sat back with a beer... then let the synaptic package manager update everything.
Time to create page: 0.164 seconds
