EMC2 Crash on startup
09 Aug 2011 16:52 #12344
by mspyle
Replied by mspyle on topic Re:EMC2 Crash on startup
I have looked at it but I am new to linux so I am not really positive on where to start.
-Matt
-Matt
09 Aug 2011 22:44 #12362
by Rick G
Replied by Rick G on topic Re:EMC2 Crash on startup
Bad numbers, to improve
Some good info here...
wiki.linuxcnc.org/emcinfo.pl?TroubleShooting
Are you using 10.04 or 8.04?
With an older machine you may want to try 8.04
Burn the 8.04 disc, boot from it and run the latency test
Rick G
Rick G
09 Aug 2011 23:02 #12363
by mspyle
I am using 10.04 its an old machine but its got mostly new hardware in it, the only old stuff is a gateway mobo and the 3ghz Pentium 4. New hardware: 4gig Corsair DDR 400 ram, video card: Nvidia GeForce GT 520 , hard drive: WD caviar blue sata 6 7200 rpm
-Matt
-Matt
10 Aug 2011 11:49 #12376
by Rick G
If anything old is the problem it could be the design of the mobo.
You also need to look at the video section for problems.
Look at video driver problems.
8.04 seems to work better on some of the older systems, 8.04 is all I run.
Everyone is new to Linux when they start.
I really would burn a 8.04 disc, boot from it and run the latency test from there, you do not have to change your system or load 8.04 to try.
Let the latency test run for a long time and tell us what your results were.
Rick G
Rick G
10 Aug 2011 15:57 #12384
by mspyle
Im gona burn the disk i=I downloaded it last night but i ran out of CDs to burn it on, as soon as its burned I will let you know the results
-Matt
-Matt
11 Aug 2011 16:31 #12430
by mspyle
Latency Test with 8.04:
___________Max interval Max Jitter
Servo thread 1028033 31528
Base thread 62173 37868
This is run off of the CD and the graphics card is not supported without a driver update (windows get all fragmented if you move them fast
-Matt
-Matt
12 Aug 2011 10:33 #12450
by Rick G
Are the numbers high right from the start, or do they spike up every say 60-90 seconds?
In this case look at the SMI fix.
Do they go high when you drag windows around?
In this case look at the video driver fix.
Also some good info here...
wiki.linuxcnc.org/emcinfo.pl?Latency-Test
Rick G
Rick G
12 Aug 2011 15:33 - 12 Aug 2011 15:34 #12461
by mspyle
the max jitter sit at 18,000-20,000 until I launched Firefox then it shot up to 40,000, but it I reset the test after launching it just sits at 19,000 ish until I move windows around then it spikes up a little + 500-1500 depending on how fast I move the window
-Matt
-Matt
Last edit: 12 Aug 2011 15:34 by mspyle. Reason: forgot signature
14 Aug 2011 01:17 #12475
by mspyle
I am starting to just give up on this old Gateway machine, I installed 8.04 on the drive today and now it takes 15 mins or so to shut down.
When I am buying new hardware is a PCIe parallel port card a viable option to run the mill off of? or should i try to find a mother board with the parallel port already on it.
Any input on what i should look at getting would be great.
-Matt
-Matt
14 Aug 2011 10:43 #12479
by Rick G
Do not worry about the shut down, it may hang on shut down but does not seem to be a problem.
Take a look here
for some examples of computers that do and do not work.
The Atom D510M0 seems to be getting popular with good numbers
www.linuxcnc.org/component/option,com_ku...,10389/lang,english/
Have you tried changing video drivers on the gateway?
19,000 might be fast enough depending on your set up.
Rick G
Take a look here
Rick G
Time to create page: 0.105 seconds
