Script bash
25 Nov 2014 18:06 #53387 by grzesiekzxr
Replied by grzesiekzxr on topic Script bash
Yes I know about " Every G code file must end in a M2 or M30 or be wrapped with the percent sign %. "
But inside this file is not presentt %.
I will try again,
thanks
25 Nov 2014 18:58 #53389 by grzesiekzxr
Thanks ArcEye Statement" file ended with no percent sign" introduced me to the error sory.
Now it's working,but it's still problem witho<.....>call.
In TERMINAL I have " Reading
,,problem with text: tag "<" "w>call "
Have any idea?
Thanks. :)
25 Nov 2014 19:04 - 25 Nov 2014 19:05 #53390 by ArcEye
Replied by ArcEye on topic Script bash
That is not any part of my code, I didn't wrapper code inside subs as Andy initially suggested, I just created new files and loaded them remotely.
You will have to post whatever you are using that produced the error
Last edit: 25 Nov 2014 19:05 by ArcEye.
26 Nov 2014 02:21 #53415 by grzesiekzxr
It is orginal file ,I just add subprogram like o<w>call [1] [2]...... :dry:
G40 G90
G54
G21 G17
G8
S600 M3
G00 Z5.000000
G00 X0 Y12.5
G01 Z-0.125000 F100
G01 X12.5 Y12.5 F400
G01 X12.5 Y0
G01 X0 Y0
G01 X0 Y12.5
G01 X12.5 Y0
G00 Z5
M5
G00 X0.0000 Y0.0000
M2
I remember that sometimes agon when I was trying GRECODE there was a problem with O<.....>call and % sign.
regards.
26 Nov 2014 15:11 #53430 by ArcEye
I know what my code was but am none the wiser about yours.
How are you wrappering in o<> subs and how are you calling them?
You keep having errors relating to % signs, which presumably means you are not terminating your code properly.
With code you posted, the M2 must be outside the sub routine block, not in it, if you are creating a sub from it
26 Nov 2014 18:23 - 26 Nov 2014 18:37 #53433 by grzesiekzxr
Hallo
Maybe this error it's becouse I have file w.ngc in wrong place, filter could not find it?
I wil try to put this sub in other places.
I atached my sub .
thanks
File Name: w.txt
File Size:2 KB
File Name: square2_20...1-26.txt
File Size:0 KB
thanks
Last edit: 26 Nov 2014 18:37 by grzesiekzxr.
26 Nov 2014 19:01 #53435 by ArcEye
Hi
Don't quite know where to start
w.txt
Your o<w> SUB has 5 o<w> ENDSUB's in the same file
You also have 5 different nested conditional loops all numbered the same
within the file
O11111 IF [[#5] GE 0]
O21111 IF [[#5] LE 54]
O21111 ENDIF
O11111 ENDIF
All subs and blocks must be uniquely numbered or named and matched by just 1 corresponding endsub or end of block
www.linuxcnc.org/docs/devel/html/gcode/o-code.html
That is before any consideration of whether the file is in the right path or named correctly.
square2_2014-11-26.txt
The o<w>call passes 5 parameters
However the sub <w> takes 9 parameters
It will be assigning the value of unset parameters and using them in the code
If they contain 0, that might not be a problem but they could contain anything.
You need to set all of them even if just with zeros to ensure the sub functions as expected.
27 Nov 2014 04:03 #53464 by grzesiekzxr
Thanks for response.
I am surprised as you becouse I 'm using this sub about a year normaly.
Last time I was doing some changes in my subprograms and I have a bit mess :)
But I tried today this sub and working properly.
No matter how much parameters put after O<w>call its working I'm a litle confused.
I know that you are right.
This is a badly written but this sub is working if I call it from normal file.
To have not any doubts I write simple :
o<example>sub
g4 p5
o<examle>endsub
Put it evrywhere where is flipfilter or my direcories from ini, but I have the same error.
Pleas tel me if when you put any o<...>call inside file sqare2.orig is it working without error for you ?
Thank you for your patience.
27 Nov 2014 04:14 #53465 by grzesiekzxr
...perhaps this sub schould have another extension,now I have example.ngc maybe it's wrong .
Tomorow I will try example.orig
regards.
27 Nov 2014 18:08 #53477 by ArcEye
I suppose it must have terminated at the first ENDSUB hence no errors?
It will work if a parameter being 0 does not do anything bad, I don't know what might happen in recursive calls
This is probably from grecode not Linuxcnc
I have no idea if it knows anything about subs, probably not.
The filter is just for flipping the axes in gcode to produce a mirror.
If your code requires calls to subs in it etc, you are probably going to have to script it, so you can stitch them in where required.
Try commenting out the o<w> call line and running it through grecode
If it does not error, you could comment out with ;;, run the call to grecode and then use sed to delete the comments afterwards.
Time to create page: 0.075 seconds
