Script bash
- grzesiekzxr
11 Dec 2014 23:29 #53929
by grzesiekzxr
Replied by grzesiekzxr on topic Script bash
...sory I don't fully understand ,could you write it for me
regards,
regards,
- ArcEye
- Thank you received: 758
12 Dec 2014 00:32 #53932
by ArcEye
#!/bin/bash
echo "M102 called"
cd /path-to/directory/for/ngc-files
rename 's/\.ngc/\.inv/' *.ngc
axis-remote --clear;
axis-remote --mdi 'G55#5381 = -1' ;
axis-remote --reload &
exit 0
Replied by ArcEye on topic Script bash
regards,
#!/bin/bash
echo "M102 called"
exit 0
The following user(s) said Thank You: eFalegname
- grzesiekzxr
12 Dec 2014 01:24 #53933
by grzesiekzxr
Now check but I still have an error:
/home/grzegorz/realtime/master/bin/invertx: 16: [0: not found
I will try it more carefully and I will report.
regads,
regads,
- grzesiekzxr
14 Dec 2014 02:12 #53995
by grzesiekzxr
Hallo'
Currently I have a problem with FILTER My filter file is:
#!/bin/sh
cat $1 |sed 's/x\([ ]*\)\([-0-9\.]*\)/x[-1*[\2]]/g'
exit 0
Firstly it was working but now I something messed up and have an error:
emc/task/emctask.cc 374: interp_error: File ended with no percent sign
nie można otworzyć /tmp/tmphaTRb3/test.inv
As You suggested corrected file M101;M102 and I have:
#!/bin/bash
echo "M101 called"
cd /home/grzegorz/linuxcnc/nc_files
rename 's/\.inv/\.ngc/' *.inv
axis-remote --mdi 'G54 #5381 = 1' ;
exit 0
#!/bin/bash
echo "M102 called"
exit 0
I wonder if it's posible to change extension only for file actualy loaded to AXIS not all in pointed directories ?
Commend CD and RENAME working ,what I see inside my nc_file but only if I click on alternating,If I click left button and then again left button or right and again right, ther is an error.
Sorry I can't completly check it becouse my FILTER not work I don' know where I make mistake?
Thank You ,
regards.
#!/bin/sh
exit 0
#!/bin/bash
echo "M101 called"
exit 0
#!/bin/bash
echo "M102 called"
exit 0
Thank You ,
regards.
- ArcEye
14 Dec 2014 03:39 #53996
by ArcEye
This is from the interpreter, you either do not have a terminating M2 or M30 or no % top and bottom, in your gcode file
- grzesiekzxr
14 Dec 2014 21:02 #54000
by grzesiekzxr
Hallo,
I was trying many ways.
Example file:
g17 g21
f2000
g1 x3 y4
m2
g17 g21
f2000
g1 x3 y4
m2
g17 g21
f2000
g1 x3 y4
m30
What is the right place to put script file for FILTER (invertx) ?
Thank You
regards.
Example file:
g17 g21
f2000
g1 x3 y4
m2
g17 g21
f2000
g1 x3 y4
m2
g17 g21
f2000
g1 x3 y4
m30
Thank You
regards.
- BigJohnT
- Thank you received: 1176
14 Dec 2014 21:20 #54001
by BigJohnT
Replied by BigJohnT on topic Script bash
Please review the G code file requirements for LinuxCNC
linuxcnc.org/docs/html/gcode/overview.html#_file_requirements
And the Program End if used in instead of the wrapping % signs.
linuxcnc.org/docs/html/gcode/m-code.html#sec:M2-M30
You do not need both and should understand the difference between them.
JT
JT
- grzesiekzxr
15 Dec 2014 02:16 - 15 Dec 2014 03:17 #54004
by grzesiekzxr
Thank You BigJohnT for reply.
Just trying it on another computer and FILTER working,no mater if % sign is together with M2 or not .
But if I look inside LINUXCNC_PRINT.TXT I see RUN_IN_PLACE=yes
I supose that is the problem ?
Probably transfering file INVERTX to /bin or download some file I'm not sure .
Now I have to recompile $ cd ~/emc2/src ?
Please let me know what do you think?
thanks
thanks
Last edit: 15 Dec 2014 03:17 by grzesiekzxr.
- grzesiekzxr
15 Dec 2014 03:50 #54007
by grzesiekzxr
........to have actual linux-print.txt I just demaged INI file (comented HALUI) and here is content:
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/grzegorz/realtime/master/bin
LINUXCNC_TCL_DIR=/home/grzegorz/realtime/master/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/grzegorz/realtime/master/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/grzegorz/realtime/master/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/grzegorz/linuxcnc/configs/biesse-346_ATC/machine.ini
PARAMETER_FILE=machine.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=6675
Killing task milltask, PID=6758
linuxcnc_debud:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
Can not find -sec DISPLAY -var INTRO_GRAPHIC -num 1
Can not find -sec DISPLAY -var INTRO_TIME -num 1
6675
PID TTY STAT TIME COMMAND
6758
Stopping realtime threads
Unloading hal components
RUN_IN_PLACE=yes
I did not check this before but I think should be RUN_IN_PLACE=no
Tell me please What exactly should Type in terminal to change (repair) it corectly?
Lack of knowledge costing me a lot of problems
RUN_IN_PLACE=yes
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
TASK=milltask
HALUI=halui
DISPLAY=axis
linuxcnc_debud:
6675
6758
RUN_IN_PLACE=yes
- grzesiekzxr
15 Dec 2014 17:11 #54014
by grzesiekzxr
Hallo,
Do You think that problem with executing FILTER file is because RUN_IN_PLACE=yes ?
On second computer FILTER working and there is RUN_IN_PLACE=NO,no mater if INI file is good or broke.
I was testing example file on comp where FILTER work:
g17 g21
f2000
g1 x3 y4
m2
above working there isn't any error
g17 g21
f2000
g1 x3 y4
m2
g17 g21
f2000
g1 x3 y4
g17 g21
f2000
g1 x3 y4
above NOT working there is error => but not the same like in first machine only :BAD CHARACTER USED '%'
Error IN first machine is :
What else could cause this problem?
Thanks,
regards.
g17 g21
f2000
g1 x3 y4
m2
g17 g21
f2000
g1 x3 y4
m2
g17 g21
f2000
g1 x3 y4
g17 g21
f2000
g1 x3 y4
Thanks,
regards.
Time to create page: 0.081 seconds
