Script bash
- grzesiekzxr
#!/bin/bash
for d in $*; do
for f in $(ls $d/*.dat); do
echo $(date) $(mv -v $f ${f%.dat}.txt)
done
done
#!/bin/bash
for d in $*; do
for f in $(ls $d/*.ngc); do
echo $(ngc) $(mv -v $f ${f%.ngc}.inv)
done
done
Whether it might work ?
regards.
- ArcEye
- Thank you received: 758
Try it
Seems a rather convoluted way to change the extension of a file, but if it works..................
- grzesiekzxr
regards.
- BigJohnT
- Thank you received: 1177
rename 's/\.dat$/\.ngc/' *dat
JT
- ArcEye
It now takes perlexpr, which basically means regex
So you can do
rename 's/\.ngc/\.inv/' *.ngc
which explains why some of my scripts stopped working properly
- BigJohnT
The tricky part in the middle is a Perl substitution with regular expressions, highlighted below:
rename -v ’s/\.htm$/\.html/’ *.htm
Tip: There is an intro to Perl regular expressions here.
Basically the "s" means substitute. The syntax is s/old/new/ — substitute the old with the new.
A . (period) has a special meaning in a regular expression — it means "match any character". We don't want to match any character in the example above. It should match only a period. The backslash is a way to "escape" the regular expression meaning of "any character" and just read it as a normal period.
The $ means the end of the string. \.htm$ means that it will match .htm but not .html.
It's fairly basic — substitute .htm with .html:
's/\.htm$/\.html/'
The last part of the command, highlighted below, means to apply the rename command to every file that ends with .htm (the * is a wildcard).
JT
- BigJohnT
On Debian at least, rename seems to have been updated.
So you can do
It takes a perlexpr on Ubuntu 10.04 too.
JT
- ArcEye
It had a 26.09.2014 datestamp on the manpage and only showed the regex type examples, so I assumed it had changed.
My previous scripts used something much more like your original syntax example
A couple of scripts I have which used it, didn't work properly last time I tried them, but that may have been something else, they were quite complex
audio and video conversion scripts using mencoder.
I just used one that used ffmpeg instead I think, so never got to the root of it
- grzesiekzxr
ArcEye;
Thank you
BigJohnT,
Just trying put it in my code but I have an error in terminal
Can't rename *.ngc *.inv: Nie ma takiego pliku ani katalogu => there is no such file and catalog.
#!/bin/bash
echo "M102 called"
axis-remote --clear;
axis-remote --mdi 'G55#5381 = -1' ;
axis-remote --reload &
exit 0
I made a mistake somewhere.
What is the proper way?
regards.
- ArcEye
The line assumes you are in the directory containing those ngc files
If not you have to explicitly cd to it first.
By default a script launched by your user is likely to start in your home dir.
