LinuxCNC/Machinekit on i.MX6 board
26 Dec 2017 14:47 #103654 by andypugh
Replied by andypugh on topic LinuxCNC/Machinekit on i.MX6 board
I would expect a different message if Xenomai was being used.
github.com/LinuxCNC/linuxcnc/blob/af15a4...pace_xenomai.cc#L171
But, I really don't know the details. I think that you need to ask on the mailing list, where it might come to the attention of the chap who addd Xenomai support.
  • savoyyang
  • savoyyang's Avatar Topic Author
  • Junior Member
  • Junior Member
27 Dec 2017 11:50 #103744 by savoyyang
Replied by savoyyang on topic LinuxCNC/Machinekit on i.MX6 board
In ~Document/linuxcnc-dev/ , I use grep -nR "uspace_xenomai.cc" * ,can't find anything in source code, Linuxcnc did not actually call this document.So I found a problem, git clone source code (Submakefile) did not include xenomai configuration, then I downloaded. Zip source code Submakefile) there are configuration on xenomai, so I use. Zip source code to install.
Use ./autogen -> ./configure --with-realtime-uspace, success, but there has been repeated make ./autogen and ./configure --with-realtime-uspace (checking and checking ... ), Did not stop for a long time, what is the problem?
I tried to replace it with ./configure --with-realtime-xenomai, but when make appeared: Makefile.inc must specify RTPREFIX and other variables.
I google it seems to need a header forum.linuxcnc.org/9-installing-linuxcnc...ust-specify-rtprefix
27 Dec 2017 12:10 #103747 by andypugh
I really don't know, and think you need to ask the people who do know.
21 Oct 2021 02:22 #223749 by SummerLotus
Replied by SummerLotus on topic LinuxCNC/Machinekit on i.MX6 board
Hello, can you share your detailed compilation steps?
I followed your steps to compile and encountered a lot of errors that the header file could not be found
> git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
> cd linuxcnc-dev
> git checkout v2.8.0-pre1
> git checkout -b myv2.8.0 v2.8.0-pre1
cd linuxcnc-dev/src
./autogen.sh
./configure --with-realtime=uspace
make
error is:
rtapi/uspace_rtapi_app.cc:38:10: fatal error: sys/io.h: No such file or directory
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
21 Oct 2021 03:31 #223763 by rodw
Replied by rodw on topic LinuxCNC/Machinekit on i.MX6 board
thats a standard C header file. Nothing to do with linuxcnc. It should exist.  have you installed build-essentials? Is the include path set for gcc?
21 Oct 2021 08:48 #223798 by SummerLotus
Do I need to configure some additional things through configure? For example, the header file directory?
When I just use the default branch, everything compiles without problems~
21 Oct 2021 15:11 #223823 by andypugh
Which kernel are you running?
It sounds like you need the kernel headers package (LinuxCNC needs this to link to the kernel modules)
I can point you at the right one, but we need the output of the terminal command "uname -a" to know what is needed.
22 Oct 2021 01:13 #223863 by SummerLotus
Hello,
You can see more details in this post
www.forum.linuxcnc.org/9-installing-linu...nuxcnc-with-xenomai3
Kernel is:
>> Linux debian10 5.4.70-xeno3 #3 SMP PREEMPT Sat Oct 16 13:37:44 UTC 2021 aarch64 GNU/Linux
The kernel is compiled manually by myself.
22 Oct 2021 11:08 #223903 by andypugh
Where is the kernel source that you compiled from?
If it is in /usr/src then I would expect the system to find it.
You might need to clear any working files from the root of /usr/src and might need a symlink linux->yourpatchedkernel
22 Oct 2021 12:40 #223913 by SummerLotus
Yes. This kernel is patched by ipipe and xenomai cobalt by myself.
I don't know if it is because I am using xenomai-3.2. Does LinuxCNC support xenomai3?
My purpose is to compile linuxcnc under xenomai3, but no matter how I try, he always tells me "Using POSIX non-realtime".
I just want to compile a real-time linuxcnc under the kernel of xenomai-cobalt, so I try any possible configuration options I find, including switching to the specified branch mentioned in this post.
Time to create page: 0.138 seconds
