Maho MH 300 C Retrofit...?
7 years 9 months ago - 7 years 9 months ago #124206 by Grotius
Replied by Grotius on topic Maho MH 300 C Retrofit...?
What you can try is put the hard drive in other pc with internet acces and cd drive. Then Install the linux iso. After that, Put it back into your machine pc and cross your fingers.
Other way is put a temponary cd drive on your machine pc. Or install it with usb. Try to hit F8 F9 F10 F11 F12.... during startup,
then you will be in bios if you are lucky.. Then you can choose your boot startup way... It can be usb boot is not active at this moment. You need to set it active. Some time's only a factory reset will do your job. This factory reset option is at the left side of bios setup.
I advise to install a 64 bit linuxcnc version. Not the old scool 32 version :laugh:
Good luck Fernandes.
Last edit: 7 years 9 months ago by Grotius.
7 years 9 months ago #124250 by Leow91
Replied by Leow91 on topic Maho MH 300 C Retrofit...?
Hi everybody,
we bought a MAHO 1000 C and want to do a Retrofit.
Could anyone Provide some Config and INI Files?
Is there a way to get some wiring plans?
We would also be able to buy the documentation including the wiring and configuration of linuxcnc!
Much Tanks to your reading and answering!
Leopold Schmidt
info@escnc.de
7 years 9 months ago #124261 by Fermaq
Replied by Fermaq on topic Maho MH 300 C Retrofit...?
Grotius wrote: ................
This bios is different from the bios I knew so far, but this configuration I have already done. Also I realized that the linux I have here is 32 bit, was ideal for the old desktop because it was what he supported, this is now 64bit ... I tried to start installation on the desktop that I use at home to see as far as it went and at one point the system said that (not compatible)
I'm looking for Linux 64 bit, but I still can not download it
7 years 9 months ago #124277 by Fermaq
Finally I got it and I think I did everything right .. (?)
I followed this video. I ask please see between video bettwen 7' and 7'40" minutes, I selected Graphical, did I do it right? :S
7 years 9 months ago #124283 by tommylight
7 years 9 months ago - 7 years 9 months ago #124289 by Fermaq
I lost, sorry
Last edit: 7 years 9 months ago by Fermaq.
Time to create page: 0.062 seconds
