Maho MH 300 C Retrofit...?
7 years 7 months ago #128281 by tommylight
Did you save the configs folder from your old installation ?
if you did all you have to do is copy them to the usual folder like /home/your_user_name/linuxcnc/configs/ and make new shortcuts on the desktop.
If you did not you have to do the new configs.
Latency looks very good.
7 years 7 months ago - 7 years 7 months ago #128291 by Fermaq
Replied by Fermaq on topic Maho MH 300 C Retrofit...?
I am still in the installation phase, and the first time when I installed the linux operating system, gmoccapy appeared by default, as I lost the password I reinstalled again but now it did not appear by default. Before it was not me that I created, so if gmoccapy before appeared by default, why now it has not appeared
Last edit: 7 years 7 months ago by Fermaq.
7 years 7 months ago #128294 by pl7i92
Replied by pl7i92 on topic Maho MH 300 C Retrofit...?
it depends on what mashine you are loading the interface to be Shown
there are multiple simulation mashines
there are new interfaces on the QTpyvcp tread look there to get your best choice
7 years 7 months ago #128323 by RotarySMP
If you replace the entry for AXIS with the following in your Ini, does it not start with Gmoccapy?
[DISPLAY]
DISPLAY = gmoccapy
Mark
7 years 7 months ago #128326 by pl7i92
if there are sidepanels or special entry gmoccapy will not load
7 years 7 months ago - 7 years 7 months ago #128372 by Fermaq
pl7i92 wrote: ...
Where I can find that? (QTpyvcp)
RotarySMP wrote: If you replace the entry for AXIS with the following in your Ini, does it not start with Gmoccapy?
Mark
But I can not find gmoccapy..., and how I replace that? For me still exist more one problem, the language, and google translator (or others) is not the best
pl7i92 wrote: if there are sidepanels or special entry gmoccapy will not load
Who is sidepanels? and what I can do for i have gmoccapy?
