PID issues or calibration help
- islander261
- Thank you received: 216
17 Jan 2019 04:12 #124318
by islander261
Replied by islander261 on topic PID issues or calibration help
Post your .hal and .ini as you have them configured.
- hatch789
17 Jan 2019 04:17 #124319
by hatch789
Replied by hatch789 on topic PID issues or calibration help
Here you go. I am pretty sure the issue is something very small at this point since I have no errors on startup. I'm just not getting any signal out of my AOUT4 and AOUT5.
Physically I have my resolver for X on Resolver04 and my resolver for Y on Resolver05
- islander261
17 Jan 2019 04:45 #124322
by islander261
Well I have no first hand experience using these cards. It looks like you are trying to use analog outputs 0 and 1 when your hal is actually using analog outputs 4 and 5.
- hatch789
17 Jan 2019 05:00 #124324
by hatch789
Give me some line numbers or something to look at and which file are you referring to for my analog outputs 0 and 1?
There doesn't appear to be anything helpful in my Tree.ini file that would lend to fixing this. All my changes were in Tree.hal
- hatch789
17 Jan 2019 05:31 #124327
by hatch789
OK I got it. I moved my AOUT0 / AOUT1 block back to P4 and reset my Tree.hal then changed only the resolver references to 04 and 05 accordingly. Everything moves again.
No I can do some testing on my F-Error and see if this improves the noise on my resolvers as PCW suggested it may.
- hatch789
18 Jan 2019 18:44 #124409
by hatch789
OK PCW now that I made that switch on P2 on my 7i49 board and adjusted the jumper. I see a bit of change in the waveform but it's still nowhere close to the pics that others had on here of their F-error. Mine is definitely more sporadic. Perhaps it's just the old servos and hardware vs new stuff? -Are there any .HAL file changes I need to do to tell it to use 1/2 voltage to reduce the noise further? Or was it just that physical block change on the 7i49 board along with the jumper?
- Online
- Thank you received: 5321
18 Jan 2019 19:16 #124413
Replied by PCW on topic PID issues or calibration help
There are no hal changes involved in the signal level change
Do you still have the periodic error?
Have you tried other axis? it may be that you have a mechanical issue
- hatch789
18 Jan 2019 19:52 #124415
by hatch789
Both X and Y behave almost identical. I can post some pics of the HALSCOPE this weekend. It is somewhat better but I'm not sure it was worth all that trouble. -Not sure if you read about my pain these past few days trying to get that change to work ...I did finally figure it out and have x & y on the P2 block.
Time to create page: 0.297 seconds
