15m Industrial Plasma Cutter
08 Aug 2019 22:28 - 08 Aug 2019 22:29 #141708 by phillc54
Replied by phillc54 on topic 15m Industrial Plasma Cutter
I think the latest update will fix your issues.
If not could you post the gcode that is causing any problems.
Edit: could you also post the error that it produces.
Last edit: 08 Aug 2019 22:29 by phillc54.
The following user(s) said Thank You: Jarman
09 Aug 2019 12:57 #141762 by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Hi Phill,
I have made my own G-code conversion tool that seems to be working so far (converting files from inkscape).
All it does is remove the movement Z commands and adds "M3 S1" before the first movement block. Is this too simplistic and should I go about getting the update? I notice for example that THC velocity lock is always on, however the files now load into plasmac and the simulation runs.
Thanks.
  • Moderator
  • Moderator
09 Aug 2019 13:04 #141765 by tommylight
Replied by tommylight on topic 15m Industrial Plasma Cutter
You do not need that, there is a plasma tool in Inkscape already, in the gcodetools menu under tools choose plasma. For comfortable use it has to be modified a bit to remove some stuff that is there for probing, but that can also be removed during editing of the drawing.
Here is a quick video with no commentary on how to output gcode for Linuxcnc.
The following user(s) said Thank You: phillc54, johnmc1, Jarman
09 Aug 2019 13:08 #141767 by phillc54
Hi Phill,
Thanks.
Whatever works for you is good, I would like to find out why the PlasmaC GCode parser is not working for your GCode.
The following user(s) said Thank You: tommylight, Jarman
09 Aug 2019 13:43 #141774 by Jarman
Thanks Tommy, I have already been following that tutorial and using the plasma features of Inkscape. My problem occurred when I tried to open those files in plasmac. My Inkscape files open directly into sample-sim-axis but not plasmac.
I'm struggling to take a screenshot in Linux but when I try to open one of the files in plasmac I get the message:
G code error in spiral.ngc
"Near line 16 of /tmp/tmp9NQ9wK/spiral.ngc
Bad character ')' used
If I press "OK", no preview loads but I can see the G code in the bottom right window.
Line 16 reads:
g1 x33.566083 y5.468631 f200.000000 (z-1.000000))
I believe that the second closed bracket is the problem. The brackets are consistent like this throughout the code.
The original line in the code from inkscape reads:
G01 X33.566083 Y5.468631 Z-1.000000 F200.000000
I have created a script that removes the Z term, changing it to:
G01 X33.566083 Y5.468631 F200.000000
This seems to work.
Also, as soon as the plasmac window opens (with no file) I get errors:
PIERCE_HEIGHT is missing from material #0
PIERCE_DELAY is missing from material #0
CUT_HEIGHT is missing from material #0
CUT_SPEED is missing from material #0
But these do not seem to be causing problems.
Thanks.
09 Aug 2019 15:36 #141785 by Jarman
Would you guys who have built plasma cutters recommend building a small scale model first (Given the size and my lack of experience)? Bearing in mind I don't have a whole lot of time to get this done (not much more that 5 weeks).
Thanks.
09 Aug 2019 16:18 #141792 by andypugh
Replied by andypugh on topic 15m Industrial Plasma Cutter
Maybe build the short axis first, make a 1D plasma cutter.
  • Moderator
  • Moderator
09 Aug 2019 17:30 #141800 by tommylight
You should take Andy's advice and start making the Z axis with floating head, then make the X axis and mount the Z axis to it. That will help a lot when you start the big Y axis.
09 Aug 2019 21:35 #141818 by rodw
Replied by rodw on topic 15m Industrial Plasma Cutter
With the timeframe, I would buy a prebuilt Z axis stage and just make the floating head slide and magnetic breakaway. I know I was doing it in my spare time but it took me 3 months to built the complete Z axis assembly.
10 Aug 2019 00:45 #141827 by phillc54
Line 16 reads:
The parser didn't like the F word in the line, I have fixed it and will push an update later today.
You really should use FF#<_hal[plasmac.cut-feed-rate]> as described here to take advantage of Velocity Anti Dive and you onlt require one F word at the beginning of your code.
They WILL cause problems when you try to cut, they are mandatory .
Time to create page: 0.114 seconds
