15m Industrial Plasma Cutter
- Thank you received: 4144
22 Aug 2019 12:52 #142837
Replied by rodw on topic 15m Industrial Plasma Cutter
Phill, the issue I experienced today is that your configurator on an upgrade creates a spindle pin for the engraver even if you don't have an engraver. So once he sorts out the permissions, that change will fix the problem until you fix your configurator.
The following user(s) said Thank You: Jarman
- Jarman
- Thank you received: 8
22 Aug 2019 13:10 #142840
by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Thanks guys.
I have attached my configs directory
- Jarman
22 Aug 2019 13:10 #142841
by Jarman
- Jarman
22 Aug 2019 14:06 #142850
by Jarman
I fixed the permission issue and commented out the line, my simulation now runs as it used to.
Thanks for the help.
- phillc54
- Thank you received: 2100
22 Aug 2019 23:08 #142888
by phillc54
Replied by phillc54 on topic 15m Industrial Plasma Cutter
Yes, I broke that, it should have been fixed herePhill, the issue I experienced today is that your configurator on an upgrade creates a spindle pin for the engraver even if you don't have an engraver. So once he sorts out the permissions, that change will fix the problem until you fix your configurator.
- phillc54
22 Aug 2019 23:13 #142890
by phillc54
All good, I was wondering why I saw "twopass:found /usr/share/linuxcnc/hallib/basic_sim.tcl" in your error report.
I didn't realise you where just running sims.
Did you copy the original sim directory and make changes where needed?
- Thank you received: 7468
22 Aug 2019 23:14 #142891
Replied by tommylight on topic 15m Industrial Plasma Cutter
- phillc54
22 Aug 2019 23:17 #142892
by phillc54
HaHa, It was really easy to do...
How could you ???Yes, I broke that, it should have been fixed here
22 Aug 2019 23:35 #142897
Haven''t you built that machine yet? Its only a tiny one, I thought you'd be able to knock it over in an afternoon ....................... ?
- phillc54
22 Aug 2019 23:38 #142899
by phillc54
HaHa, I thought the same with mine.
The following user(s) said Thank You: rodw, Jarman
Time to create page: 0.173 seconds
