15m Industrial Plasma Cutter
22 Aug 2019 09:23 #142824 by rodw
Replied by rodw on topic 15m Industrial Plasma Cutter
Yeah I didn't run make. Just the two commands I posted above.
Is there a specific command I should be using to do that?
Thanks.
Basically, copy the buildbot line in the link Phill posted and paste it onto the command line
If you still get the error, then comment out the line as I suggested.
The following user(s) said Thank You: Jarman
22 Aug 2019 11:14 #142827 by phillc54
Replied by phillc54 on topic 15m Industrial Plasma Cutter
I don't think I had my brain in gear, it seems you are using a buildbot install so you don't need to run make.
Could you open a terminal and run man plasmac and let me know the version number.
22 Aug 2019 11:21 #142828 by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Thanks for clarifying Phill, that makes sense.
I ran man plasmac and got:
VERSION 0.66 - 19 Aug 2019
It also says "PLASMAC(9)" at the top but I don't know if that is version related.
22 Aug 2019 11:28 #142829 by phillc54
When was your last update?
22 Aug 2019 11:33 #142830 by Jarman
It was this morning at about 9am (UK) time, 3.5 hours ago. I have been away and not using the computer since the 13/08/19 so I think when I updated this morning it updated to that version (ie. It did successfully update). Am I missing a version?
22 Aug 2019 11:34 #142831 by phillc54
Do you have a line in your machine HAL file beginning with loadrt [EMCMOT]EMCMOT and does it have num_spindles=2 at the end.
22 Aug 2019 12:24 #142832 by Jarman
I'm not entirely sure what is meant by machine HAL.
I have the file "plasmac.hal"
located: /usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/plasmac.hal
Is this what you mean?
This file has the line:
"loadrt plasmac"
however I can't see a reference to the number of spindles. I have attached the file so you can see what I'm looking at.
Thanks.
File Name: plasmac.hal
File Size:3 KB
22 Aug 2019 12:31 - 22 Aug 2019 12:31 #142833 by rodw
Try this file instead of the one you have. Based on my experience today I would expect this to work. All I've done is comment out a pin you don't need as you don't have an engraver. as I mentioned earlier in this thread.
File Name: plasmac_20...8-22.hal
File Size:3 KB
EDIT: rename it to plasmac.hal
Last edit: 22 Aug 2019 12:31 by rodw.
22 Aug 2019 12:33 #142835 by Jarman
Thanks Rod,
I tried to do that myself earlier but didn't have permission to save. I'll figure out how to open as administrator and then see if it works.
22 Aug 2019 12:47 #142836 by phillc54
You shouldn't need administrator permissions, you config directory should be in your home directory, something like /home/jarman/linuxcnc/configs/
I would not recommended that you comment lines out, I would rather find out what the real problem is so we don't have issues down the track.
Could you zip your config directory and I can take a look tomorrow.
Time to create page: 0.229 seconds
