15m Industrial Plasma Cutter
- Thank you received: 4144
19 Sep 2019 13:14 #145585
45XP is About 14 kg with a torch on 6 metre lead
Replied by rodw on topic 15m Industrial Plasma Cutter
How much does the plasma weigh? If it's a low-power one for thin material it might be surprisingly light.
The following user(s) said Thank You: Jarman
- Jarman
- Thank you received: 8
19 Sep 2019 13:30 #145587
by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
A bit too much for a 1.25m gantry I would think.
- Thank you received: 4652
19 Sep 2019 15:20 #145592
Replied by andypugh on topic 15m Industrial Plasma Cutter
How much of that 14kg is the 6m lead?
Though it's maybe worth bearing in mind that if you put the power supply on the gantry then the earth lead needs to come off on the cable chain.
But the earth lead might cope better with the flexing.
- Thank you received: 7468
20 Sep 2019 08:17 #145651
Replied by tommylight on topic 15m Industrial Plasma Cutter
14Kg ????
I had an italian made inverter 45A plasma, it was 38Kg with cables.
Put the electronics on one side of the gantry, you need only a power and ethernet cable. Get a switch mode power supply, it is lighter than any version of toroidal/rectifier/capacitor combo ( it is lighter than only the rectifier with cooler and capacitors ).
How did you get to 6M for the cable on a 15M machine ?
You will have to put the plasma on the other side of the gantry ( never on the same side with electronics ).
That ends up needing a power cable, a network cable and an air tube in long dimensions, and makes for a neat machine.
Some things are not negotiable at that size.
Or maybe i missed something and you are doing a smaller one ???
- Jarman
23 Sep 2019 12:57 #145952
by Jarman
Hi Tommy,
The cutting length is 12m so I only need 6m if the plasma is in the middle. So I thought that a 10.7m torch would handle it.
23 Sep 2019 13:27 #145957
You also need another 3 meters for the gantry and the Z as they will have to move and bend, so need some slack.
12 should be the minimum, and even that might prove quite problematic to route properly.
Try the Trafimet web site, i did get some 12M ones with machine torch for something like 500 euro a piece here and they are of very high quality.
shop.trafimet.com/en/products/PLASMA/Automatic+torches+HF/
In theory yes, but reality has a way of messing things, like bends and attachments to other things and it can not be very near the moving machine etc.Hi Tommy,
- Jarman
25 Sep 2019 08:42 #146142
by Jarman
With regard to leaving the cutter in operation, the existing industrial CNC at the company are monitored while in use but they are largely very reliable. How easy is it for a hobby CNC to be built with this kind of reliability and are there specific things that I should be aware of (like shielding and dust protectors etc.)
25 Sep 2019 09:07 #146145
LinuxCNC controls many machines that are definitely not Hobby machines. Tormach is one example of an industrial one You could follow my lead and add a stacklight so you can see status from a distance.
25 Sep 2019 09:10 #146146
Not easy, but it is possible, for sure.
Mount the rails and racks so they can be covered as much as possible, or make sure the machine is cleaned often if they are not covered.
Use shielded cable, always for plasma, do some reading on proper shielding.
Time to create page: 0.474 seconds
