7i96 step + or -, + other question
- Leon82
- Thank you received: 79
22 Nov 2019 15:28 - 26 Nov 2019 07:52 #150975
by Leon82
7i96 step + or -, + other question was created by Leon82
On my parallel port I had to invert the step pin for my drives to run on their presents in stepconf.
Should I use the step - plug on the 7i96?
Last edit: 26 Nov 2019 07:52 by Leon82.
- Thank you received: 7504
22 Nov 2019 15:50 #150978
Replied by tommylight on topic 7i96 step + or -
If it works properly, leave it as is.
The following user(s) said Thank You: Leon82
- Leon82
22 Nov 2019 16:56 #150982
by Leon82
I haven't hooked anything up yet, I figured I would ask
Replied by Leon82 on topic 7i96 step + or -
- Thank you received: 5336
22 Nov 2019 18:04 #150991
Replied by PCW on topic 7i96 step + or -
Probably STEP-
STEP+ will have positive step pulses
Normally this will suit drives with the optcoupler common connected to GND
STEP- will have negative step pulses
Normally this will suit drives with the optcoupler common connected to +5V
- Leon82
26 Nov 2019 07:57 #151295
by Leon82
Replied by Leon82 on topic 7i96 step + or -, + other question
Thanks. I'm still laying everything out on a panel but have another question.
I have a treadmill motor with a 2100 control. People have made pwm pulse generators to use them without the treadmill panel like this pic.
Can I use the pwm from the 7i96 with it?
I would think so I just need to figure out the wire schematic. The blue is pwm signal. I would imagine a ground has to go to the board also.
And energize it with the spindle pin thru a relay.
26 Nov 2019 10:26 #151303
Replied by PCW on topic 7i96 step + or -, + other question
Be careful...
Is this PWM input isolated from line voltage?
- Leon82
26 Nov 2019 10:42 #151306
by Leon82
I'm not sure if this will help
I believe so. There is an on board transformer and one of the wires sends 9 volts to the control panel.Be careful...
- Leon82
27 Nov 2019 22:34 #151404
by Leon82
I have found a few videos where people use an AC motor control with a bridge rectifier.
They usually have to change to a 200k potentiometer for better scaling.
Could I use this instead of a potentiometer?
store.mesanet.com/index.php?route=produc...t_id=205&search=spin
- grandixximo
- Thank you received: 412
28 Nov 2019 00:22 - 28 Nov 2019 00:30 #151407
by grandixximo
Replied by grandixximo on topic 7i96 step + or -, + other question
I would remove the Blue PWM 0-5V from the motor controller to the console, and in its stead hook a pwmgen output from the 7i96 to the console, the 7i96 is able to get the 5v square wave signal you need, the page you sent is very vague about the square wave required, but i think is a very low HZ wave maybe 100HZ or so.
But PCW is the expert, you may want to wait for his opinion...
Last edit: 28 Nov 2019 00:30 by grandixximo.
- Leon82
28 Nov 2019 05:30 #151416
by Leon82
Yea, I want to be sure before I try it
I have read 16 an 20hz for this control
Time to create page: 0.249 seconds
