7i96 step + or -, + other question
06 Dec 2019 19:03 #152199 by Leon82
Replied by Leon82 on topic 7i96 step + or -, + other question
I picked up some relays and they had a socket for the diode and picked up some of them
The side with the plus goes on the positive coil supply? I tested it direct to the power supply and it closes wired that way.
I also got a cheap pwm generator to play with and it also worked on the controller.
At 20hz the motor starts and the duty cycle works from about 15 to 95%.
The red and brown are the 12 volts that would go to the treadmill panel and are powering the generator
  • Moderator
  • Moderator
06 Dec 2019 19:24 #152201 by tommylight
Replied by tommylight on topic 7i96 step + or -, + other question
Now we're cooking ! :)
Test also some higher frequency PWM, like 100 or 1000 Hz, check if you can notice any change in sound of the motor, it should sound much smoother. I would venture on the safe side a 5000 and on the "are you nuts" side 22000 to 25000.
The following user(s) said Thank You: Leon82
06 Dec 2019 20:03 #152206 by PCW
Replied by PCW on topic 7i96 step + or -, + other question
Alternatively. if 20 Hz is OK, you could use a 7I96 isolated output driven by a software PWM generator running at the servo thread rate, and get full isolation of the control signal
06 Dec 2019 20:12 #152208 by Leon82
i think i am going to try that. i have to get the motor mounted and make a pulley.
07 Dec 2019 13:22 #152276 by Leon82
Which coil wire for the relay is best to run to the output? Ground or +12v
10 Dec 2019 17:27 #152463 by Leon82
i set an output to turn on a relay for the driver power supply
net machine-is-on <= halui.machine.is-on
net machine-is-on => hm2_7i96.0.ssr.00.out-03
it is not hooked up to the relay yet but i noticed the led on the board will blink once and stay on after i hit the machine on button.
the output for the spindle just turns on. is this something with the internals of linux cnc?
10 Dec 2019 17:43 - 10 Dec 2019 17:43 #152464 by PCW
I don't see any blinking with Axis+halui, this may be GUI related
Spindle operation depends entirely on hal wiring
Last edit: 10 Dec 2019 17:43 by PCW.
10 Dec 2019 17:57 #152465 by Leon82
Ok, I'll try it with gmocappy and see if I get it.
10 Dec 2019 18:40 #152466 by Leon82
This is what it does. I checked it with the multimeter and It closes and I tried another output . I think it's is something with software.
10 Dec 2019 22:54 - 10 Dec 2019 22:58 #152469 by PCW
Which GUI?
As I said this does not happen with Axis in my tests
(also you should be able to plot this with halscope)
Last edit: 10 Dec 2019 22:58 by PCW.
Time to create page: 0.642 seconds
