7i96 step + or -, + other question
- Leon82
- Thank you received: 79
11 Dec 2019 03:56 #152476
by Leon82
Replied by Leon82 on topic 7i96 step + or -, + other question
I used axis and gmocappy.
I'll take a look at halscope after work today
- Leon82
11 Dec 2019 16:26 #152500
by Leon82
Using qtpyvcp it goes on solidly. No blink
- Thank you received: 5336
11 Dec 2019 16:57 #152502
Replied by PCW on topic 7i96 step + or -, + other question
It may have to do with your specific hal connections
I don't see any blink with Axis either
The following user(s) said Thank You: Leon82
- grandixximo
- Thank you received: 412
11 Dec 2019 17:34 #152504
by grandixximo
Replied by grandixximo on topic 7i96 step + or -, + other question
Can you post your qtpyvcp and your axis Hal and ini files?
- Leon82
11 Dec 2019 17:44 #152505
by Leon82
The following user(s) said Thank You: grandixximo
- grandixximo
11 Dec 2019 18:18 #152506
by grandixximo
I think your problem maybe here.
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
net remote-estop estop-latch.0.fault-in <= hm2_7i96.0.gpio.000.in
Try to change to a simpler
net estop-test hm2_7i96.0.gpio.000.in => iocontrol.0.emc-enable-in
- Leon82
09 Jan 2020 17:09 #154497
by Leon82
So, for software pwm on an output....
Do i supply 5 volts to the output and it will cycle the relay at the frequency?
I need type,0 1 wire
20 Hertz frequency
Duty cycle min 15-20
Duty cycle max 90-94(motor stalls at 95)
20 Hertz frequency
- Leon82
12 Jan 2020 08:07 #154671
by Leon82
It looks like the card doesn't like pwm mode 0.
Can you run mode 1 without the dir signal?
12 Jan 2020 08:21 #154672
Its not the mode, its that the standard firmware has no pwmgen
If you want a low frequency PWM on an isolated output you would have to load the software PWM component:
loadrt pwmgen output_type=0
addf pwmgen.make-pulses servo-thread
setp pwmgen.0.pwm-freq 20
setp pwmgen.0.enable true
net lowfreqpwm hm2_7i96.0.ssr.00.out-00 pwmgen.0.pwm
- Leon82
12 Jan 2020 08:53 #154675
by Leon82
Thank you,
I did load the 4 step +q pwm from big John's tool
I will experiment with the software pwm
Time to create page: 0.606 seconds
