7i96 step + or -, + other question
12 Jan 2020 15:08 - 12 Jan 2020 15:08 #154677 by PCW
Replied by PCW on topic 7i96 step + or -, + other question
For hardware PWM there is no output_type 0
(Though I guess the driver could implement this )
So if you enable the hardware PWMgen you get both PWM and direction
on the Step/Dir 4 pins. If you disable the hardware pwmgen (or stepgen4 in
normal firmware) you can use the step/dir 4 pins as general purpose outputs
for software PWM etc
Last edit: 12 Jan 2020 15:08 by PCW.
The following user(s) said Thank You: Leon82
12 Jan 2020 15:13 #154678 by Leon82
Replied by Leon82 on topic 7i96 step + or -, + other question
1 more question,
Does the software pwm on the output generate the 5v signal or am I required to run 5 volts to the output (and the output generates the pulse from that by cycling the relay)
12 Jan 2020 15:19 - 12 Jan 2020 15:25 #154679 by PCW
Which output?
The step/dir outputs are 5V signals but with limited (24 mA) drive
The SSR outputs are switches and can switch 0 to 36V at up to 2A
Last edit: 12 Jan 2020 15:25 by PCW.
12 Jan 2020 15:27 - 12 Jan 2020 15:28 #154680 by Leon82
One of the isolated ones (ssr)
Last edit: 12 Jan 2020 15:28 by Leon82.
12 Jan 2020 15:36 #154682 by PCW
The SSR outputs are simply switches always require and external supply to power a load
for example
+5V --> OUT00+ ---> OUT00- --> Load+ --> Load- --> GND
for a 5V load device
Note that you need a flyback diode across mechanical relay coils
Also note that the SSR outputs are not protected against shorts so
test with a current limited supply or make sure your circuit works
with a mechanical switch substituted for the SSR outputs before wiring
to the 7I96
12 Jan 2020 15:37 #154683 by Leon82
Ok, thanks.
I figured, just wanted to make sure
12 Jan 2020 15:53 #154685 by Leon82
Although it sounds easier to use the dir from step4
12 Jan 2020 16:06 #154687 by PCW
If you are driving a mechanical relay the SSR output is more suitable
If you are driving an Optocoupler or AC SSR the Step/DIr outputs shoud be fine
The step/dir outputs are only rated 24 mA which will not drive most 5V
mechanical relays. The SSR outputs can drive 5VDC, 12VDC, or 24VDC relays
or contactors
12 Jan 2020 16:13 - 12 Jan 2020 16:20 #154688 by Leon82
I'm going to send the pwm signal to the treadmill motor controller, which only has 1 wire needed
So currently the SSR relay I'm planning to connect to machine on. Which will energize the controller.
Then on spindle on I would start the PWM signal
I'm not sure how I would close the circuit using an output when I only need the 1 wire
Last edit: 12 Jan 2020 16:20 by Leon82.
12 Jan 2020 17:54 #154702 by Leon82
How can I change this
net lowfreqpwm hm2_7i96.0.ssr.00.out-00 pwmgen.0.pwm
To make the pulses on step+4 pin on spindle cw? I set it back to 5 step gens
Time to create page: 0.172 seconds
