Mitsubishi RV-6SDL Robot arm Servo/Encoder usability
  • Aciera
  • Aciera's Avatar Topic Author
  • Administrator
  • Administrator
25 May 2024 17:35 #301423 by Aciera
Do you know if any other control has a paradigm for this? Other than defining ad-hoc planes for each arc, which seems clumsy.
i don't, the only way to produce arcs in arbitrary planes i know is the tilted work plane feature (ie G68.x and affiliated  gcodes).
25 May 2024 20:58 - 25 May 2024 20:59 #301443 by Ehsan_R
Thanks David
I must say that I did not understand much from your conversation
I think I should spend more time understanding inverse kinematics equations.
And also get more skill in working with linuxcnc.
Last edit: 25 May 2024 20:59 by Ehsan_R.
  • Aciera
  • Administrator
  • Administrator
26 May 2024 09:16 #301466 by Aciera
Unfortunately, at the present state, one doesn't seem to get around the math. Which is probably one of the reasons why there tend to be so few people interested in this area of LinuxCNC. Or maybe they just don't bother sharing their work.
Regarding inverse kinematics for manipulator with spherical wrists:
Also helpful are these two documents regarding the Posemath library often used in LinuxCNC.
Note that 'genserkins' seems to be using a different library called 'gomath', if I recall correctly.
File Name: PoseMath.tar.gz
File Size:130 KB
The following user(s) said Thank You: DPFlex
27 May 2024 13:39 #301588 by meister
because the Denavit-Hartenberg parameters are very difficult for me to adapt to other robots,
I have written a small tool to visualize it.
I'm not sure if it's really correct and if it could help someone.
but it is easier for me to get an understanding of it.
If anyone here is familiar with the parameters, they can take a look at it.
Greetings,
 Olli
The following user(s) said Thank You: tommylight, Aciera
  • Aciera
  • Administrator
  • Administrator
27 May 2024 16:06 #301596 by Aciera
Looks good, I'd like to have a look at it. Where can I get it from?
Note that 'genserkins' uses a modified Denavit-Hartenberg parameter system. The original system orders the values differently.
  • Moderator
  • Moderator
27 May 2024 16:34 #301601 by tommylight
The following user(s) said Thank You: meister, Aciera
  • Aciera
  • Administrator
  • Administrator
27 May 2024 17:08 #301606 by Aciera
Ok, once I figured out that it wants to be pointed to the melfa_dh.hal I got it working.
$ python git/linuxcnc-robot-logger/dh-parameter.py linuxcnc-292-feb/configs/sim/axis/vismach/melfa-sim/melfa_dh.hal
Looks nice.
I don't have much time just now but here is something not quite right in the way the D-parameters are applied. A-offset values are always in the direction of the current X-axis and the D values along the Z-axis. This is correct for A-0,D-0 but the D-1 value is applied in world-x-direction instead of the current-Z-direction (which at this point is pointing in the world-y-direction.)
Have you seen my documentation:
linuxcnc.org/docs/html/motion/dh-parameters.html
  • Aciera
  • Administrator
  • Administrator
27 May 2024 17:12 #301607 by Aciera
Note that in the 'modified' DH-System the angular rotation (ie 'ALPHA-n') is always applied before the 'A' and 'D'.
IIRC this is different from the standard DH-system.
15 Jun 2024 12:32 #303047 by Ehsan_R
Hello
How can I increase the speed limit in world coordinates?
And what is your reason for putting this speed limit?
  • Aciera
  • Administrator
  • Administrator
15 Jun 2024 14:07 - 15 Jun 2024 14:08 #303049 by Aciera
Speed limits for 'World' and for 'Joint' kinematics mode are set by the [AXIS_l] MAX_VELOCITY values.
The problem here is that in 'Joint' kinematics axis X is a rotational joint while in 'World' kinematics axis X is a virtual linear axis. This usually means that the same value will be too fast for Joint kinematics and too slow in World kinematics.
It probably makes sense to switch Velocity/Acceleration settings when switching kinematics.
The setup is the same as for switching limits which I have done in the demo config in this post:
forum.linuxcnc.org/39-pncconf/52783-soft-limit-setup#301669
Last edit: 15 Jun 2024 14:08 by Aciera. Reason: Forgot the link
Time to create page: 1.283 seconds
