help, no stepper movement
12 Apr 2020 23:11 #163818 by motal2004
help, no stepper movement was created by motal2004
plasma table
Mesa 7I96
570 oz stepper motors KL-5046 driver
uname -a
Linux debian 4.9.0-8-rt-686-pae #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) i686 GNU/Linux
I went through the Pncconf process and it created a shortcut on my desktop. but I get no movement. yes i hit the enable button and homed the joints, but nothing. am i missing something.
I was using promas myplasm cnc system so i know my table works.
12 Apr 2020 23:18 #163820 by tommylight
13 Apr 2020 00:03 #163824 by motal2004
Replied by motal2004 on topic help, no stepper movement
When I ping I get operation not permitted
13 Apr 2020 00:18 #163825 by motal2004
Thanks tommylight , I can see the network issue I have, will tackle It tomorrow
15 Apr 2020 01:31 #163999 by motal2004
I ping 10.10.10.10 I get a read out
I do get a pin read out when i do command messflash -- device 7i96 --addr 10.10.10.10 - - readhmid
I did the pnnconfig but still no movement.
My mini pc has 2 Ethernet ports.
I followed the network steps but I still get
Port 1 device not managed
Port 2 device disconnected
What else can I do ?
15 Apr 2020 01:59 - 15 Apr 2020 02:01 #164002 by PCW
Replied by PCW on topic help, no stepper movement
By far the most common cause of lack of motion in step/dir systems is too short
step pulses, I would start with 5000,5000 for steplength/stepspace
"Port 1 device not managed"
Is expected if you have setup port 1 in the interfaces file
Last edit: 15 Apr 2020 02:01 by PCW.
16 Apr 2020 03:09 #164107 by motal2004
tommylight so i can ping the card i do a mesaflash -- device 7i96 --addr 10.10.10.10 - -readhmid i get a pin out but no movement when i try to move joints. I know it has something to do with network.so reading through some old forums i tried some command lines and i get the whats below. base on the last couple lines what should i do ?
linuxcnc:~$ halrun
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip=10.10.10.10
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:16:00:86
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Low Level init 0.15
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0: IO Pin 000 (TB3-01): IOPort
hm2/hm2_7i96.0: IO Pin 001 (TB3-02): IOPort
hm2/hm2_7i96.0: IO Pin 002 (TB3-03): IOPort
hm2/hm2_7i96.0: IO Pin 003 (TB3-04): IOPort
hm2/hm2_7i96.0: IO Pin 004 (TB3-05): IOPort
hm2/hm2_7i96.0: IO Pin 005 (TB3-06): IOPort
hm2/hm2_7i96.0: IO Pin 006 (TB3-07): IOPort
hm2/hm2_7i96.0: IO Pin 007 (TB3-08): IOPort
hm2/hm2_7i96.0: IO Pin 008 (TB3-09): IOPort
hm2/hm2_7i96.0: IO Pin 009 (TB3-10): IOPort
hm2/hm2_7i96.0: IO Pin 010 (TB3-11): IOPort
hm2/hm2_7i96.0: IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96.0: IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96.0: IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96.0: IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96.0: IO Pin 015 (TB3-21/TB3-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i96.0: IO Pin 016 (TB3-23/TB3-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i96.0: IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 025 (TB2-01/TB2-03): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i96.0: IO Pin 026 (TB2-04/TB2-05): PWMGen #0, pin Out1 (Dir or Down) (Output)
hm2/hm2_7i96.0: IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input)
hm2/hm2_7i96.0: IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input)
hm2/hm2_7i96.0: IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input)
hm2/hm2_7i96.0: IO Pin 030 (TB2-16/TB2-17): IOPort
hm2/hm2_7i96.0: IO Pin 031 (TB2-18/TB2-19): IOPort
hm2/hm2_7i96.0: IO Pin 032 (internal): IOPort
hm2/hm2_7i96.0: IO Pin 033 (internal): SSR #0, pin AC Ref (Output)
hm2/hm2_7i96.0: IO Pin 034 (P1-01): IOPort
hm2/hm2_7i96.0: IO Pin 035 (P1-02): IOPort
hm2/hm2_7i96.0: IO Pin 036 (P1-03): IOPort
hm2/hm2_7i96.0: IO Pin 037 (P1-04): IOPort
hm2/hm2_7i96.0: IO Pin 038 (P1-05): IOPort
hm2/hm2_7i96.0: IO Pin 039 (P1-06): IOPort
hm2/hm2_7i96.0: IO Pin 040 (P1-07): IOPort
hm2/hm2_7i96.0: IO Pin 041 (P1-08): IOPort
hm2/hm2_7i96.0: IO Pin 042 (P1-09): IOPort
hm2/hm2_7i96.0: IO Pin 043 (P1-11): IOPort
hm2/hm2_7i96.0: IO Pin 044 (P1-13): IOPort
hm2/hm2_7i96.0: IO Pin 045 (P1-15): IOPort
hm2/hm2_7i96.0: IO Pin 046 (P1-17): IOPort
hm2/hm2_7i96.0: IO Pin 047 (P1-19): IOPort
hm2/hm2_7i96.0: IO Pin 048 (P1-21): IOPort
hm2/hm2_7i96.0: IO Pin 049 (P1-23): IOPort
hm2/hm2_7i96.0: IO Pin 050 (P1-25): IOPort
hm2/hm2_7i96.0: registered
sysctl: cannot stat /proc/sys/net/ipv6/conf/eth0:avahi/disable_ipv6: No such file or directory
hm2_eth: ERROR: Failed to execute '/sbin/sysctl -q net.ipv6.conf.eth0:avahi.disable_ipv6=1'
halcmd:
16 Apr 2020 03:20 - 16 Apr 2020 04:01 #164108 by PCW
How have you setup the network, with the network manager or
editing /etc/network/interfaces?
What does
ip a
report?
(pretty sure the avahi error means that you have not disabled ipv6 on eth0, though I don't
think that will interfere with normal operation as the correct device registration shows)
Note that "no movement when i try to move joints." is not likely to be a network issue unless
there are such severe network latency issues that you get a watchdog timeout. If this happens
you should get a warning from LinuxCNC about a real time error.
Lack of communication will result in other LinuxCNC errors
(and joint following errors when you try to move joints/axis)
Last edit: 16 Apr 2020 04:01 by PCW.
16 Apr 2020 09:43 #164126 by tommylight
Replied by tommylight on topic help, no stepper movement
Attach hal and ini files.
Do the motors lock when you power them up?
what drives and what are the DIP settings on them ?
16 Apr 2020 13:46 #164137 by motal2004
here are the ip -a and ip link show
i also included the the network interfaces section. i have not mess with , i used the network manager on the top right corner as per tommylight previous response
@linuxcnc:~$ ip -a
Usage: ip [ OPTIONS ] OBJECT { COMMAND | help }
ip [ -force ] -batch filename
where OBJECT := { link | address | addrlabel | route | rule | neigh | ntable |
tunnel | tuntap | maddress | mroute | mrule | monitor | xfrm |
netns | l2tp | fou | macsec | tcp_metrics | token | netconf | ila }
OPTIONS := { -V[ersion] | -s[tatistics] | -d[etails] | -r[esolve] |
-h[uman-readable] | -iec |
-f[amily] { inet | inet6 | ipx | dnet | mpls | bridge | link } |
-4 | -6 | -I | -D | -B | -0 |
-l[oops] { maximum-addr-flush-attempts } | -br[ief] |
-o[neline] | -t[imestamp] | -ts[hort] | -b[atch] [filename] |
-rc[vbuf] [size] | -n[etns] name | -a[ll] | -c[olor]}
azcnc@linuxcnc:~$ ip -a
azcnc@linuxcnc:~$ ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether b4:2e:99:58:6b:2f brd ff:ff:ff:ff:ff:ff
azcnc@linuxcnc:~$
This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
Time to create page: 0.164 seconds
