help, no stepper movement
- motal2004
- Thank you received: 16
19 Apr 2020 22:45 #164682
by motal2004
Replied by motal2004 on topic help, no stepper movement
Any idea how/or what I did , to cause the driver failure? , so I don’t do it again. And can this be repaired?
- Thank you received: 5321
20 Apr 2020 14:26 #164863
Replied by PCW on topic help, no stepper movement
A common cause would be shorting the STEP/DIR outputs to some voltage outside
the 0 to 5V range (12V 24V 36V etc) even for an instant
Another possibility is >7V applied to the 7I96 5V power connection
- motal2004
20 Apr 2020 19:00 #164881
by motal2004
thanks for the info.
