New Mill Build...Can I use LinuxCNC?
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 5 months ago #168625 by Mayberry Customs
Replied by Mayberry Customs on topic New Mill Build...Can I use LinuxCNC?
Looking at the gmoccapy documentation all the photo illustrations seem to be gone?
6 years 5 months ago #168635 by rodw
Replied by rodw on topic New Mill Build...Can I use LinuxCNC?
I think you might be looking at master branch docs. I raised an issue about that. Were fine under V2.8 a few days ago.
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 5 months ago #169599 by Mayberry Customs
Working on wiring the board now...I want to use a tool setter at some point so I can take advantage of the auto tool measurement in gmaocapy ...is this consider a “digital input” and do I wire it the same way as the limit switches?? Thanks, Andy
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 5 months ago - 6 years 4 months ago #169665 by Mayberry Customs
I’m talking about a tool setter similar to the picture...Can anyone help me with how to wire something like this to the 7i76e? I’m assuming it’s wired just like a limit switch then just simply configured as a tool probe or tool setter in pcconfig. You can also see in the picture that it can be wired to alarm out if it goes past it’s travel, is this also connected to another input on the board? The simple diagram picture is from a different tool setter but one that looks very similar Thanks, Andy
Last edit: 6 years 4 months ago by Mayberry Customs.
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 1 month ago - 6 years 1 month ago #182758 by Mayberry Customs
I am finally ready to run the wiring on my machine. I am getting ready to Hook the VFD to my Mesa 7i76E. I have attached the diagrams that were included with the Chinese VFD. I have Norberts diagram but I am not sure how to make all the connections as the terms don’t correlate between each diagram. Can anyone help me with this? Any help would be greatly appreciated. Thank you, Andy
Last edit: 6 years 1 month ago by Mayberry Customs.
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 1 month ago #182762 by Mayberry Customs
Just a quick update on the progress. Like I said, in the middle of wiring and running coolant lines etc.
Time to create page: 0.863 seconds
