New Mill Build...Can I use LinuxCNC?
6 years 2 weeks ago #186400 by rodw
Replied by rodw on topic New Mill Build...Can I use LinuxCNC?
I have used the Longs Motor DM542a and these settings work (I know they are super short) I think I used 20x microstepping.
DIRSETUP = 500 DIRHOLD = 500 STEPLEN = 1000 STEPSPACE = 1000 STEP_SCALE = 1000
All I did was to connect the wiring direct to the mesa stepgen
Step+ to Pul+
Step- to Pul-
Dir+ to Dir+
Dir- to Dir-
I did notice there was a different wiring layout for Parallel ports.
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 2 weeks ago #186409 by Mayberry Customs
Replied by Mayberry Customs on topic New Mill Build...Can I use LinuxCNC?
Ok i have attached the .hal and .ini. I can try the different wiring later tonight. Rod i will try those settings before i try the wiring change.Thanks.
6 years 2 weeks ago #186412 by rodw
What voltage are your motors at?
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 2 weeks ago #186413 by Mayberry Customs
Just tried these settings...still the same thing. Thanks, Andy
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 2 weeks ago #186415 by Mayberry Customs
According to the spec sheet I posted, wired as the middle variance, they are 8.96v if that is what you are referring to. Thanks
6 years 2 weeks ago - 6 years 2 weeks ago #186416 by rodw
What voltaqe power supply for the steppers? 48v, 70v what?
Last edit: 6 years 2 weeks ago by rodw.
Time to create page: 0.277 seconds
