New Mill Build...Can I use LinuxCNC?
6 years 1 week ago #186511 by rodw
Replied by rodw on topic New Mill Build...Can I use LinuxCNC?
This diagram from Lam shows how Microstepping works to smooth out motion (800 steps/rev on left, 25600 steps/rev on right)
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 1 week ago #186525 by Mayberry Customs
Replied by Mayberry Customs on topic New Mill Build...Can I use LinuxCNC?
Ok I will continue to experiment...I am starting to see that the big NEMA 34’s and 5mm pitch ball screws might not be the best combination...one lingering question I have and something I couldn’t find a definitive answer for is the current setting on the drivers...if a spec sheet like the one I posted says 1.4A per phase, do I set the drivers for that rating or since it’s a 4 phase motor do I multiply that 1.4A by 4 and set the drivers at 5.6A.
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 1 week ago #186531 by Mayberry Customs
Ok after researching other NEMA 34 steppers available, it’s obvious it’s closer to 6A... This is most likely my main problem. Thanks
6 years 1 week ago #186533 by tommylight
Replied by tommylight on topic New Mill Build...Can I use LinuxCNC?
Mayberry Customs wrote: ...if a spec sheet like the one I posted says 1.4A per phase, do I set the drivers for that rating or since it’s a 4 phase motor do I multiply that 1.4A by 4 and set the drivers at 5.6A.
If a spec sheet says 1.4A you set the drives to 1.4A.
If they are 1.4A and Nema 34, do not expect much speed from them.
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 1 week ago #186535 by Mayberry Customs
Ok thanks for the clarification. Andy
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 1 week ago #186539 by Mayberry Customs
If I need to change these motors out, are there any NEMA 34’s that someone can specifically recommend? Or what to look for in general for something that is higher speed...The drives are rated up to 7.8A. I am seeing now across the internet that this is a common problem with these longs motor kits...I guess this is why I got a “great deal” on the motor and driver package lol
Time to create page: 0.567 seconds
