New Mill Build...Can I use LinuxCNC?
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 2 weeks ago #186417 by Mayberry Customs
Replied by Mayberry Customs on topic New Mill Build...Can I use LinuxCNC?
60v power supply’s, one for each driver. Thanks
6 years 2 weeks ago #186420 by rodw
Replied by rodw on topic New Mill Build...Can I use LinuxCNC?
Maybe try Peter's wiring suggestion.
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 2 weeks ago #186421 by Mayberry Customs
Ok that’s the next thing I will try. Thank you
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 2 weeks ago #186431 by Mayberry Customs
Just tried this alternative wiring on one axis, did not make any difference. Thanks
6 years 2 weeks ago #186438 by PCW
Replied by PCW on topic New Mill Build...Can I use LinuxCNC?
P is set wrong in the ini file. Its set for 10000 which will result in oscillations.
It should be set to 1/servo period or 1000 for a 1 ms (1000000 ns) servo thread
period.
  • Mayberry Customs
  • Senior Member
  • Senior Member
6 years 2 weeks ago #186439 by Mayberry Customs
Ok, can you clarify on how to fix this? Is this a setting in pncconfig or do I go into the .ini file adjust it? Thanks a lot, Andy
Time to create page: 0.353 seconds
