2 seperate MPG handwheels for each axis - CNC Lathe build
6 years 5 months ago - 6 years 5 months ago #168035 by denhen89
I am not at home right now, but I wrote just minutes ago quiet a lot on my phone but when I posted it I got a "kunena internal error". As soon as will be back at home i will reply to all your answers.
Last edit: 6 years 5 months ago by denhen89.
6 years 5 months ago #168039 by denhen89
Alright, i am back at the test PC.
@PCW: Thanks for that! Now i do understand that the input pins 16 and 17 dont need to be somewhere in the HAL, because those pins are already linked with "hm2_7i76e.0.7i76.0.0.enc0.count". Correct?
To count, the inputs must swing below 2V and above 3V relative to field ground
So, 4.10V is totally fine.
@rodw: I have read your build thread many times, really, but my problem is, i have no switches at all, so i dont know what i have to change in the HAL so that the MPG is always active just to test it.
The only thing I thought of is that if you don't have the axis select switch installed, you might have to setp the MPG scale pin to a value. If it is 0 , nothing will happen.
Thats a good point. Make sense for me, but again i dont know what i have to enter/change in the HAL to set one scale which is always active, so that no switches are needed.
It seems that i would need to study all those codes for linuxcnc and the complete MESA 7i76e manual or so, but i want to be honest: I want a working machine and not be a pro in Linuxcnc setup. Some time ago i wanted to set up a test pc and learn classic ladder etc., but i do not have a lot of time anymore, so i want spent my free time with other things than something which i will not really need a lot in future. Of course i would like to understand the configuration, because later when the mechanical part on the Lathe is done, i want a panel with a switch for the scale change (ordered the same as you have, but i already wrote that i think on page 1). Also i want to have some buttons to start/stop g code, but right now i just do not want to think about it. As soon as i get the switch for the scale and some buttons i will start thinking about that.
In my next post i will precisly explain my current setup, so that it will be easier to help me out.
6 years 5 months ago #168042 by rodw
Thats the thing. There is not a dedicated support desk so you need to work a few things out yourself.
Where I said
net x-jog-scale mux4.0.out => axis.x.jog-scale
Try
setp axis.x.jog-scale 1
Assuming a metric machine, that will give you a 1mm step. Change it to suit if you are in inches ot it will move 1 inch per click!
I might ad that I di move 1 meter per click once!
6 years 5 months ago #168043 by denhen89
So, i just upgraded to Linuxcnc 2.9 pre.
Debian vers. 9
Wiring of MPG to Mesa 7i76e: See picture:
*GND from TB3 Pin 9 is connected to GND of TB3 Pin 23
I used PCCONF to create a RAW setup. See pictures:
Everything else has been not set up and left as default.
After the set up i changed in the HAL the sserial port: sserial_port_0=2xxxx
I attached the .HAL and .INI file
I started Linuxcnc, opened the Halmeter and unfortunately nothing happens when turning the MPG handwheel, no matter which Pins enc0 pins i choose. See picture:
Do i understand it correctly, that if the wiring of the MPG is correct, then something should happen in the Halmeter when selecting the correct Pin ?
To remember: I have no switches to select the scale also no buttons to enable to MPG, so as Rodw wrote, i would need to set a standard scale. Also i would need to have the MPG active without any buttons to press.
I hope that are all informations you need to help me out.
Of course, in meantime until i get some help i will try to get it done by my self and not just wait until someone helps :)
Thanks in advance guys.
6 years 5 months ago #168044 by denhen89
@Rodw: Of course i understand to find out a lot of things by my self, but i really tried but its difficult for me.
Thanks for "setp axis.x.jog-scale 1", but if in Halmeter nothing happens when turning the handwheel, then i think that the problem might be in the wiring, or am i wrong ?
6 years 5 months ago #168045 by rodw
Can you chexk what I used here
sserial_port_0=200xxxx
I have a feeling I might have been different.
If the mode is right and it is not counting, then look at wiring.
Time to create page: 0.204 seconds
