Thanks a lot! I found the HAL files and you even eplained most steps or maybe even all (i will find out as soon as i get the 7i76E). This should help me a lot when setting up the MPGs and also use some warning lights.
I did not read everything to be honest, because i have now a bit work to do, but i saw that you used 3 different scales (0.01mm, 0.1mm, 1,00mm), as i want to have it too, but how do you change them, with buttons?
Thanks in advance:)
EDIT: Sorry, i found on the same page (page 3), that you explained how you installed a switch to change the scale. I am currently on the Aliexpress page to find buttons for the scale change. I would like to use seperate buttons for each scale. Am i right that it would be easier than use that kind of switch as you have used? (due to the binary logic that is required)
I am not that good with with those programming stuff, so i would like to make the setup as easy as possible.
EDIT Nr.2 : I will do it as you have done it, with the 2 pole 6 position switch: Just ordered that one:
www.aliexpress.com/item/4000687267288.ht...1.0.0.27424c4dhpJbs6
Hope you will help me out if i will have any problems setting it up
