New Project with Mesa 7I96 and THCAD-05
5 years 5 months ago #210890 by snowgoer540
Are you using arc-lost-delay in your Hal files at all?
If so, if you are not on the latest version there was a bug that would not allow the THC to activate if there was an arc lost delay set between 0-1 seconds.
5 years 5 months ago #210900 by TexasCNC
snowgoer540 wrote: Are you using arc-lost-delay in your Hal files at all?
I need to check not at my computer right now. Where do I look for that?
5 years 5 months ago #210905 by snowgoer540
Honestly, if you didn’t add it, it’s not set by default. Just wanted to mention it in case you had set it :)
5 years 4 months ago #210925 by phillc54
Is the THC Enabled LED on while cutting?
Does the THC Active LED turn on while cutting?
Do the Up/Down LEDs turn on while cutting?
Do you have Mesh Mode or Ignore Arc OK enabled?
Could you post the backup of the config.
5 years 4 months ago #210935 by TexasCNC
phillc54 wrote: Is the THC Enabled LED on while cutting? Yes
Does the THC Active LED turn on while cutting? Yes
Do the Up/Down LEDs turn on while cutting? No
Do you have Mesh Mode or Ignore Arc OK enabled? I am not sure where do I check that? When running that job the z motor burnt out cause it won’t go up anymore I hear the motor whining when trying to go up but won’t move. It moves down I even swapped out driver and still does the same so I think it might of messed up stepper motor or it just gave out. Ordered another one don’t come until Friday. I have a spare on my other running machine but right now that one is working.
5 years 4 months ago #210937 by phillc54
That doesn't sound to good...
Warning: Spoiler!
Time to create page: 0.472 seconds
