New Project with Mesa 7I96 and THCAD-05
- TexasCNC
- Thank you received: 10
13 Jun 2020 19:50 #171475
by TexasCNC
New Project with Mesa 7I96 and THCAD-05 was created by TexasCNC
Installed linuxcnc 2.7.14 and then upgraded to 2.8 since I have been seeing that mesa 7I96 works with this version. I filled out the pnconfig wizard and I saw that the 7I96 card is in the drop down menu and idnt think I need to use the configuration tool for it? Anyways I filled out the rest of the tabs and tried opening it and get the error that is attached. I am testing this on my kitchen table with the card hooked up and pinging I will hook up driver and motors once I can get the gui working. Any ideas what it can be or can I just upgrade to 2.9 is that supported with new setup of the mesa 7i96 card?
- Thank you received: 7489
13 Jun 2020 20:01 #171476
Replied by tommylight on topic New Project with Mesa 7I96 and THCAD-05
We need the error report, not linuxcnc info, nothing there that would help.
No need to go to 2.9 or master if you do not plan to develop or test any new features.
- Thank you received: 5332
13 Jun 2020 20:10 #171479
Replied by PCW on topic New Project with Mesa 7I96 and THCAD-05
Best thing is to start LinuxCNC from the command line
( by typing linuxcnc in a terminal window )
and copy-paste the messages and post them here
- TexasCNC
13 Jun 2020 20:24 #171483
by TexasCNC
Replied by TexasCNC on topic New Project with Mesa 7I96 and THCAD-05
- TexasCNC
13 Jun 2020 20:27 - 13 Jun 2020 20:37 #171484
by TexasCNC
I am not an expert in linuxcnc pretty much this forum has been a big help and wanted to add more stuff to my plasma table and I was pointed towards the mesa cards and wanted to try them out currently have 2.9 on my other machine and working fine but with chinese breakout board.
Last edit: 13 Jun 2020 20:37 by TexasCNC.
13 Jun 2020 20:42 #171485
You have the wrong kernel for eth cards, you need preempt-rt, not RTAI.
The Stretch version has the kernel required, here
www.linuxcnc.org/testing-stretch-rtpreempt/
Or use the Linux Mint or Debian 10.4 howtos to install a new version of Linux and Linuxcnc, here:
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
or
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
or
- TexasCNC
13 Jun 2020 20:45 #171487
by TexasCNC
Ahh I see let me see if i can figure this out
- TexasCNC
13 Jun 2020 20:50 #171489
by TexasCNC
Whats the easiest way to do this since I have liniux running right now and hooked up to internet? Do i need to have a usb boot program?
- Thank you received: 4151
13 Jun 2020 21:07 #171493
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
I would start again. Save your config somewhere safe. I'd just copy it to Google Drive but I guess a USB stick would do.
Then I would install the Stretch PREMPT_RT ISO and install V 2.8
But one of the unofficial ISOs might come with V 2.8 installed already.
Just be aware that the PREMPT_RT might increase latency to such an extent that new PC hardware is required... Thats what I found anyway.... but I was on 32bit hardware..
- TexasCNC
13 Jun 2020 21:23 #171496
by TexasCNC
What program in linuxcnc can I use to make a file bootable or just to upgrade from m y current version?
Time to create page: 0.441 seconds
