New Project with Mesa 7I96 and THCAD-05
6 years 4 months ago #171475 by TexasCNC
New Project with Mesa 7I96 and THCAD-05 was created by TexasCNC
Installed linuxcnc 2.7.14 and then upgraded to 2.8 since I have been seeing that mesa 7I96 works with this version. I filled out the pnconfig wizard and I saw that the 7I96 card is in the drop down menu and idnt think I need to use the configuration tool for it? Anyways I filled out the rest of the tabs and tried opening it and get the error that is attached. I am testing this on my kitchen table with the card hooked up and pinging I will hook up driver and motors once I can get the gui working. Any ideas what it can be or can I just upgrade to 2.9 is that supported with new setup of the mesa 7i96 card?
File Name: linuxcnc_info.txt
File Size:3 KB
6 years 4 months ago #171476 by tommylight
Replied by tommylight on topic New Project with Mesa 7I96 and THCAD-05
We need the error report, not linuxcnc info, nothing there that would help.
No need to go to 2.9 or master if you do not plan to develop or test any new features.
6 years 4 months ago #171479 by PCW
Replied by PCW on topic New Project with Mesa 7I96 and THCAD-05
Best thing is to start LinuxCNC from the command line
( by typing linuxcnc in a terminal window )
and copy-paste the messages and post them here
6 years 4 months ago #171483 by TexasCNC
Replied by TexasCNC on topic New Project with Mesa 7I96 and THCAD-05
6 years 4 months ago - 6 years 4 months ago #171484 by TexasCNC
I am not an expert in linuxcnc pretty much this forum has been a big help and wanted to add more stuff to my plasma table and I was pointed towards the mesa cards and wanted to try them out currently have 2.9 on my other machine and working fine but with chinese breakout board.
Last edit: 6 years 4 months ago by TexasCNC.
6 years 4 months ago #171485 by tommylight
You have the wrong kernel for eth cards, you need preempt-rt, not RTAI.
The Stretch version has the kernel required, here
www.linuxcnc.org/testing-stretch-rtpreempt/
Or use the Linux Mint or Debian 10.4 howtos to install a new version of Linux and Linuxcnc, here:
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
or
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
Time to create page: 0.276 seconds
