New Project with Mesa 7I96 and THCAD-05
- TexasCNC
- Thank you received: 10
14 Jun 2020 16:05 #171616
by TexasCNC
Replied by TexasCNC on topic New Project with Mesa 7I96 and THCAD-05
I am getting same error that was attached earlier and here are the hal and ini files
- Thank you received: 5332
14 Jun 2020 16:09 #171617
Replied by PCW on topic New Project with Mesa 7I96 and THCAD-05
You have the host IP address (10.10.10.11) in your hal file rather than
the card address (10.10.10.10)
- TexasCNC
14 Jun 2020 16:41 #171621
by TexasCNC
I have been switching back and forth to .10 and .11 and still the same
14 Jun 2020 16:44 #171622
10.10.10.11 will not work so just set the hal number to 10.10.10.10
what does
ip a
report?
what does
ip a
report?
- TexasCNC
14 Jun 2020 20:33 #171639
by TexasCNC
- TexasCNC
14 Jun 2020 20:48 #171640
by TexasCNC
ok I just tried it and now it works i can get into the gui. Now the next question do I need to run the 7i96 configuration tool to set it up I already set it up through pncconfig? How will the THCAD-5 connect to and if I wanted to add the THCAD-10 later how will i activate the other encoder input?
14 Jun 2020 21:13 #171645
No, the 7i96 configuration utility and pncconf are two different configuration tools.
Any changes now should be done by editing the hal/ini files or running the calibration
utility
If you have a single THCAD it connects to the 7I96 encoder inputs
To have multiple THCADs you would need to install the 7i96dpl.bit firmware
and then the next THCAD connects to the encoder "B" pins
utility
7I96 THCAD
+5 --> +5
GND --> GND
A --> FOUT+
/A --> FOUT-To have multiple THCADs you would need to install the 7i96dpl.bit firmware
- Thank you received: 4151
14 Jun 2020 21:14 #171646
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
On Mesa's website for the 7i96, there is a zip file to download. In it there will be a bit file that the file name included 7i96 and ends in pl.bit
So you use mesaflash to download it to the 7i96.
- TexasCNC
14 Jun 2020 23:26 #171656
by TexasCNC
I saw the Mesaflash how do I get that installed.
14 Jun 2020 23:40 #171658
To get the latest version you would need to fetch the source:
github.com/LinuxCNC/mesaflash
and build/install it
There are instructions for this on the bottom of the github page
Time to create page: 0.182 seconds
