linuxcnc 2.8 release problem
- Clive S
- Thank you received: 486
09 Sep 2020 16:53 - 10 Sep 2020 09:18 #181464
by Clive S
linuxcnc 2.8 release problem was created by Clive S
I have downloaded the new release iso 2.8
I cannot get it to load. I have downloaded and made the bootlable usb with balenaEtcher
The problem is that it hangs after it has just configured the network connections
It stops with "Configure The Network" with Debian in a dark blue band at the top of the screen
I have downloaded it twice and tried graphical and Install. I have tried using different HD's.
I then tried the new install from Mr Beagle with the new 2.8 mint 19.3 that went fine.
Could this be that the debs have not got around the world yet?
Edit; I have now tried this on a different PC and it installed OK without issues
Last edit: 10 Sep 2020 09:18 by Clive S. Reason: added text
- Thank you received: 2177
09 Sep 2020 17:58 - 09 Sep 2020 18:00 #181476
Replied by Aciera on topic linuxcnc 2.8 release problem
It installed just fine for me today on a HP elite 8300 SFF and on another HP machine. I use Disk Image Writer in Linux to create the bootable USB.
From here www.linuxcnc.org/iso/linuxcnc-2.8.0-buster.iso
Last edit: 09 Sep 2020 18:00 by Aciera.
- Clive S
10 Sep 2020 09:20 #181590
by Clive S
Yes I have tested in on another PC and it installs OK.
One question where are the power management and screensaver settings located.?
Replied by Clive S on topic linuxcnc 2.8 release problem
10 Sep 2020 12:48 #181621
It's not installed:
> sudo apt install xfce4-power-manager
- Clive S
10 Sep 2020 13:25 - 10 Sep 2020 13:30 #181630
by Clive S
Yes that works. thanks.
Now I need the network manager
and auto log in
should these be missing in the new 2.8
It's not installed:
and auto log in
Last edit: 10 Sep 2020 13:30 by Clive S.
10 Sep 2020 13:53 - 27 Nov 2020 06:58 #181631
network manager -> right click on the network icon in the top right corner
auto login:
sudo nano /usr/share/lightdm/lightdm.conf.d/01_debian.conf
Gives:
Add (using you username for <user_name>:
Then do
sudo nano /etc/lightdm/lightdm.conf
And uncomment two lines plus enter your user name
Worked for me.
auto login:
Gives:
Warning: Spoiler!
# Debian specific defaults
# - use lightdm-greeter session greeter, points to the etc-alternatives managed
# greeter
# - hide users list by default, we don't want to expose them
# - use Debian specific session wrapper, to gain support for
# /etc/X11/Xsession.d scripts
[Seat:*]
greeter-session=lightdm-greeter
greeter-hide-users=true
session-wrapper=/etc/X11/Xsession
# greeter
[Seat:*]
Warning: Spoiler!
[SeatDefaults]
autologin-user=<user_name>
autologin-user-timeout=0
Then do
Warning: Spoiler!
[Seat:*]
#autologin-guest=false
autologin-user=<nome user>
#autologin-in-background=false
#autologin-session=
#exit-on-failure=false
#autologin-session=
Worked for me.
Last edit: 27 Nov 2020 06:58 by Aciera.
- Clive S
10 Sep 2020 13:57 #181632
by Clive S
Is all this stuff really missing form the new release?
- BeagleBrainz
- Visitor
10 Sep 2020 14:08 #181635
by BeagleBrainz
Replied by BeagleBrainz on topic linuxcnc 2.8 release problem
That’s Debian for you.
I know on Stretch there were bits and pieces missing that made it really annoying.
- Clive S
10 Sep 2020 14:15 #181637
by Clive S
Thanks I actually use your iso with mint But you indicated that you might stop your server in the near future.
10 Sep 2020 14:16 #181639
I usually opt for Linux mint Debian edition (LMDE) that is a lot more polished but for a machine controller I can live with this.
There is also a LinuxMint ISO that's really nice.
Time to create page: 0.156 seconds
