linuxcnc 2.8 release problem
11 Sep 2020 20:19 #181788 by rodw
Replied by rodw on topic linuxcnc 2.8 release problem
From what I have read, LMDE is using the Debian repositories so therefore should be able to access the Debian PREEMPT_RT package.
So to get PREEMPT_RT I think you just need to install LMDE and then type
sudo apt-get install linux-image-rt-amd64
or something similar.
See packages.debian.org/buster/linux-image-rt-amd64
But Tommy lists a few other bits and pieces required in his quick and easy install for Linuxcnc.
The day seems to be getting closer that PREMPT_RT will be in the main line of the Linux kernel. How nice would that be?
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
11 Sep 2020 21:39 #181798 by BeagleBrainz
Replied by BeagleBrainz on topic linuxcnc 2.8 release problem
I'm a bit perplexed why Debian repos are used for getting Linuxcnc to run on Mint 20 when the Ubuntu Bionic & the Linuxcnc Mint repo work and doesn't break building a RIP installation later on.
On the Linucnc github there has been talk of some 5.6.x & 5.4.x kernel having issues with Mesa etherent.
There are other issues mixing Debian packages on a Ubuntu based system, one I have seen is building kernel modules, ie: for hardware not supported in the mainline kernel. So I would propose trying to use Ubuntu packages for Mint rather than Debian packages.
Debian packages should be fine for LMDE but do add issues for Ubuntu based Mint
12 Sep 2020 07:17 #181831 by rodw
That was what I was suggesting. My comment was specifically fro LMDE
  • BeagleBrainz
  • Visitor
  • Visitor
12 Sep 2020 10:47 #181871 by BeagleBrainz
Just wanted to make sure the differences were expressed, in my bone headed way ;)
23 Sep 2020 10:04 #183442 by seuchato
Replied by seuchato on topic linuxcnc 2.8 release problem
Hi all
Hope this post is in the correct corner.
I had a network problem with a buster based iso taken from here
Installed the iso via usb stick on one machine (dell 980, no network problems here) and then transferred it to another (Fujitsu D956). On the Fujitsu I had no more network, although nic status leds where flickering all the time.
To overcome the problem, I did:
  1. Disable ipv6: in /etc/sysctl.conf I added "net.ipv6.conf.all.disable_ipv6 = 1", rebooted, no ip
  2. networkctl list
    WARNING: systemd-networkd is not running, output will be incomplete.
    IDX LINK             TYPE               OPERATIONAL SETUP
      1 lo               loopback           n/a         unmanaged
      2 enp0s31f6        ether              n/a         unmanaged
      3 enx801f02d64b9d  ether              n/a         unmanaged
    3 links listed.
  3. systemctl start systemd-networkd
  4. ifup enp0s31f6
So, I finally got my network back. Should someone have a similar or same problem, it hopefully helps to resolve
greez
chris
26 Sep 2020 15:04 - 26 Sep 2020 15:04 #183849 by Henk
Replied by Henk on topic linuxcnc 2.8 release problem
Hi.
I installed the 2.8 buster iso on a Lenovo M72 i3 tiny pc. The install completed without errors but when trying to boot from the newly installed hard drive it errors stating "No operating system found"
I tried UEFI and legacy mode, quick boot disabled. The sata drive shows up in the boot menu but it doesn't boot.
Any advice is appreciated
Henk
Last edit: 26 Sep 2020 15:04 by Henk. Reason: I meant i3. Not i2...
  • BeagleBrainz
  • Visitor
  • Visitor
26 Sep 2020 21:01 #183884 by BeagleBrainz
Sounds like grub didn't install correctly.
I'd try setting to legacy mode and reinstalling.
Was there a previous installation of Windows on the hdd ?
27 Sep 2020 03:26 #183923 by Henk
Yip. Win 7.
I'll try that. Thanks
27 Sep 2020 04:00 #183924 by Henk
That worked. Thanks
The following user(s) said Thank You: BeagleBrainz
19 Jan 2021 05:03 #195869 by davidgs171
Replied by davidgs171 on topic linuxcnc 2.8 release problem
I have the downloaded and installed Linuxcnc 2.8 and Debian Buster- I have a user account and password, when I attempt to run a sudo command I am asked for a password but it will not accept any characters- how does a user become a superuser or administrator- all fixes for no return from hibernation or autologin require a sudo or su command; I don't find anything in the GUI - obviously I am a Windows user attempting to get Linux configured.
Time to create page: 0.676 seconds
