linuxcnc 2.8 release problem
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
19 Jan 2021 08:08 - 19 Jan 2021 08:09 #195871 by BeagleBrainz
Replied by BeagleBrainz on topic linuxcnc 2.8 release problem
If you created a root pass word you can get root access by copying and pasting the below.
su -
Then follow this:
glenngillen.com/thoughts/adding-yourself-to-the-sudoers-file
Last edit: 19 Jan 2021 08:09 by BeagleBrainz.
19 Jan 2021 09:19 #195873 by anfänger
Replied by anfänger on topic linuxcnc 2.8 release problem
are you sure the you can’t write. You don’t see what you are writing and the are also no white characters. Did you try typing your user password an press enter?
su - will give you root access but since you didn’t provide a root password this might not work.
sudo su - is my way to go
19 Jan 2021 09:55 #195875 by rodw
Replied by rodw on topic linuxcnc 2.8 release problem
when you type a password in linux, all data entered is hidden so it looks like nothing is happening, just type and hit enter.
19 Jan 2021 17:22 #195901 by davidgs171
Replied by davidgs171 on topic linuxcnc 2.8 release problem
OK, that explains why I see a white box and nothing else when typing the password.
Thank You.
19 Jan 2021 17:29 #195902 by davidgs171
I did try entering my password even though nothing showed; was not accepted; I remember being asked only once for a user and password on install, nothing about root or using root as user- . I may have to delete athe partition and reinstall? Thanks for your help.
19 Jan 2021 17:33 #195905 by davidgs171
I did not create a root password on the install; I recall only one opportunity to enter a user and password- perhaps I should have used root as the user then? I am ready to delete the partition and re-install if this is the case. Thank You.
19 Jan 2021 22:24 #195928 by Clive S
Replied by Clive S on topic linuxcnc 2.8 release problem
Are you sure that you have entered the PSW in the correct box.
As there can be 2 boxes the first is for the user name and then the second box pops up for the PSW
19 Jan 2021 23:21 - 19 Jan 2021 23:21 #195937 by andypugh
Replied by andypugh on topic linuxcnc 2.8 release problem
The installer deliberately does not set a root password, as if you give a root password during install then "sudo" is disabled. (???)
Last edit: 19 Jan 2021 23:21 by andypugh.
  • Moderator
  • Moderator
19 Jan 2021 23:37 #195941 by tommylight
Replied by tommylight on topic linuxcnc 2.8 release problem
Are you using the official Buster ISO?
Pretty sure Andy mentioned some time ago something about removing the root password option, but i might be wrong, and do not know how it went afterwards.
Anyway, do not enter a root password, just click "next" and enter a new user and a password, twice, i think you mentioned you were asked once .... or was it another topic ... or another forum ... ???
  • Moderator
  • Moderator
19 Jan 2021 23:38 #195943 by tommylight
And now i see Andy answered, so i'll go hide under a rock for a while! :)
Time to create page: 0.333 seconds
