- Thank you received: 5334
PCW wrote: its in the ini file
Can you plot the tool changer position command?
Does it really have a 1000 degree step?
I have done an edit in the previous post.
I will try and do a plot in the morning . What do I plot the tool changer command against for the trigger
I have to stop now have been called for dinner. thanks again
Mike_Eitel wrote: I dont see that you have somewhere backlash compensation BUT I see the same 5
MAX_ACCELERATION = 5 and STEPGEN_MAXACCEL = 5
Maybe a bit higher value (6) for stepgen does the job?
Mike
