5i25/6i25 bitfile for DMB4350-8B bob
- Thank you received: 5321
13 Feb 2021 00:10 #198621
Replied by PCW on topic 5i25/6i25 bitfile for DMB4350-8B bob
So does 10000 work (scaled right) for inches?
You may have set the scale way off in mm so the motion is very small
- 0jw
13 Feb 2021 00:16 #198623
by 0jw
Replied by 0jw on topic 5i25/6i25 bitfile for DMB4350-8B bob
It's moving in millimeters now but it's still moving twice the distance
13 Feb 2021 00:28 #198624
Sounds like the drive is using 1000 steps/turn
if a stepscale of 393.70079 (0.1968503937 TPMMx2000)
moves twice as far as expected
- 0jw
13 Feb 2021 00:57 #198628
by 0jw
According to the DYN4 drives manual "Gear_Numis 500, means 2000steps will turn motor ONE revolution, and Gear_Num= 1000, means4000steps will turn motor one revolution.In general, 4 * Gear_Numsteps will turn motor one turn"
it is set to 500 for a 2000 steps per revolution. maybe something to do with older firmware on the drives. I'll try set the drives to (Gear_Num=1000) for 4000 steps per revolution
- 0jw
13 Feb 2021 01:13 #198630
by 0jw
this didn't fix the problem.
13 Feb 2021 01:44 #198633
Sounds like the DMM scaling is not working as expected.
Does the machine motion change when you change the DMM scaling?
- 0jw
13 Feb 2021 02:09 #198634
by 0jw
yes it scales accordingly.
with a gear ratio Num of 500x4=2000. 200 steps in pncconf and stepconf will move 1 rotation.
with a gear ratio Num of 1000x4=4000. 400 steps in pncconf and stepconf will move 1 rotation.
- 0jw
13 Feb 2021 02:18 - 13 Feb 2021 02:20 #198635
by 0jw
I think I will set gearNum 4000x4=16,000 or gearNum 2000x4=8,000 and 1,600 or 800 steps for now. hopefully it is doing something similar to microstepping inside the drives. But I may have to update the firmware.
I don't think this is a problem with new drives. These are from when the dyn4 was first released.
Last edit: 13 Feb 2021 02:20 by 0jw.
- 0jw
13 Feb 2021 03:52 #198645
by 0jw
X and Y axis are working along with limit switches. but not Z axis. it looks like i need pin 6 for Dir and pin 7 for step. so IO 9 and IO 10
13 Feb 2021 03:58 #198647
Stepgen 2 is on pins 6 and 7:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort PWMGen 0 PWM (Out)
14 1 IOPort None
2 2 IOPort StepGen 0 Dir (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Step (Out)
16 5 IOPort None
4 6 IOPort StepGen 1 Dir (Out)
17 7 IOPort None
5 8 IOPort StepGen 1 Step (Out)
6 9 IOPort StepGen 2 Dir (Out) <<<<<<<<<<
7 10 IOPort StepGen 2 Step (Out) <<<<<<<<<<
8 11 IOPort StepGen 3 Dir (Out)
9 12 IOPort StepGen 3 Step (Out)
10 13 IOPort None
11 14 IOPort QCount 0 Quad-A (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-IDX (In)Please Log in or Create an account to join the conversation.
Time to create page: 0.139 seconds
