5i25/6i25 bitfile for DMB4350-8B bob
- 0jw
13 Feb 2021 12:14 #198671
by 0jw
Replied by 0jw on topic 5i25/6i25 bitfile for DMB4350-8B bob
it ended up being that some of my cables were wired differently. I'm guessing dmm changed some things down the line.
but i think i just messed it all up trying to install this vistacnc pendant and I have no idea if an of it will work with probe basic.
- 0jw
13 Feb 2021 14:39 #198678
by 0jw
I'm trying to set up a vistacnc ps-2 pendant. I had commented out a bunch of stuff in the vc-p2s.hal file and got linux to open. but of course that didn't work.
I uncomented it all and now get the error
./vc-p2s.hal:8: pin "halui.axis.0.pos-relative' does not exist.
Trying to read over Hal basics. but slow progress
- 0jw
13 Feb 2021 22:33 - 13 Feb 2021 22:34 #198739
by 0jw
I enabled pyvcp in pncconf and now linuxcnc opens. but i get error
"hm2/hm2_5i25.0: stepgen.00.maxvel is too big for current step timings & position-scale, clipping to max possible
hm2/hm2_5i25.0: stepgen.01.maxvel is too big for current step timings & position-scale, clipping to max possible
hm2/hm2_5i25.0: stepgen.02.maxvel is too big for current step timings & position-scale, clipping to max possible"
Last edit: 13 Feb 2021 22:34 by 0jw.
- Thank you received: 5321
13 Feb 2021 23:18 #198748
Replied by PCW on topic 5i25/6i25 bitfile for DMB4350-8B bob
Those errors mean that you cannot move at the selected velocities
with the current step timings (step length and step space) and position
scale, so you must shorten your step timings or reduce your maximum
velocities (or change the scale)
- 0jw
13 Feb 2021 23:24 #198751
by 0jw
I did this according to the settings in the dyn4 manual and changed it in pncconf. but now i am getting the same error as before.
13 Feb 2021 23:39 #198752
You might want to put off the pendant setup until you have the basics
working (including homing)
- 0jw
13 Feb 2021 23:53 #198756
by 0jw
Ok, I thought maybe I was skipping some stiff or doing something that will just end up getting overwritten in pncconf. I have max limits+home working but inverted at the moment and travel set very small so the machine cant easily crash. e-stop and probe work from the bob and I can hear a relay turning on when linuxcnc starts. hopefully that's the charge pump.
- 0jw
14 Feb 2021 00:37 #198768
by 0jw
Not sure what else I should be doing to set things up other than maybe getting Probe Basic to work and entering tool offsets. any suggestions?
- Thank you received: 7468
14 Feb 2021 11:34 #198790
Replied by tommylight on topic 5i25/6i25 bitfile for DMB4350-8B bob
Did you get the machine working?
- 0jw
14 Feb 2021 20:27 - 15 Feb 2021 21:39 #198837
by 0jw
Yes, I got the dmm bob to work smoothly with the 6i25. Although some supplied dyn4 cables were different. so it created a bit of confusion. All corrected and working now.
Still no luck with the pendant. I tried following some examples on here of people who got it working with mesa cards and it seemed to make my machine move on power up and crash.
Last edit: 15 Feb 2021 21:39 by 0jw.
Time to create page: 0.563 seconds
